OK I need to figure this out. I want a 60" plus screen to hook my PC up took and game it up on. I want to be able to play at 1920x 1080 resolutions my computer can handle it fine allready but how do you do it with overscan cutting off the outside of the screens I know all about overscan compensaiton basically dropping your resolution to some crazy custom res to make it fit without being cut off and i can do that for my desktop but not for games! so how the hell do you guys do this im going crazy !!!
HOW IS TRUE HTPC GAMING POSSIBLE??? or does everyone just deal with the edges of all there screens being cut off to play in their HDTV's native resolutions??
Which HDTV's are you using to hook your PC's up do and what are you doing about overscan?
PLease someone tell me they have a HDTV hooked up and they set there resolutions to 1920x 1080 and everythings fine.
AND WHY THE HELL IS EVERYONE OK WITH "1080p" HDTV's NOT BEING ABLE TO ACTUALLY DISPLAY A 1920x1080 IMAGE WITHOUT CUTTING OFF THE EDGES!!
We should all demand that if you say a unit can display that resolution it better damn well do it!
Jordan is goign NUTS!
