Here is my plan for cheap acoustic panels. Please let me know if these should work and not look too terrible.
1: Cut sheets of 1/4" plywood to 2'x4' and use spray adhesive to attach 2" Roxul AFB Mineral Wool.
2: Wrap some cotton quilting around and staple on the back.
3: Wrap some finishing material around and staple on the back.
Would using Ownens Corning 703 make much difference. It costs nearly twice as much as the mineral wool.
I would make bass traps using the super-chunk corner method in the corners and make a frame to string cloth over to hide the mineral wool.
Does this plan sound like it would work? Any flaws you can see?
