So I replaced my old"er" Belkin Wireless Router today with the Linksys WRT54GL. I updated the firmware to DD-WRT V23 SP2.
I setup everything correctly using the DD-WRT control panel. I even enabled port forwarding for the PS3 although I'm pretty sure it's not really necesary.
Anywho... The PS3 is reporting a signal of between 78-87. Seems like a pretty good signal right?
Then why are my DL speeds so terrible? I tested using speakeasy.net/speedtest using the PS3 and get about 1,000 kbps. I used my HTPC right next to the PS3 (also wireless) and got 13,400 kbps.
I'm beginning to think the PS3 can't handle very much when running wireless. Maybe just enough to make online play possible?
Anyways... I'm thinking about ways to get the PS3 wired to something that's wireless.
I'm a little lost though as I don't know too much about this kind of stuff. I'm thinking it's possible to connect another WRT54GL Router in my entertainment system and run cat5 wires to both my HTPC and PS3. I could then set that up to grab the internet from my other WRT54GL right? Is that possible?
I'm assuming the above would work. Would this be the best option for me to get the PS3 connected to the internet using the LAN port on the back?
If it is... what types of changes will I need to make to my current router and what would I need to change on the 2nd router? Any links to guides on setting something like this up would be appreciated.
If it's not the best way to go about this, what would be the best way?
Thanks in advance to anyone that can help
