Originally Posted by VKR
Plex, thanks for your help. I may just go with the Denon AVR-2112CI to pick up the MultiEQ XT. I wasn't big on the Marantz, but HiDef Lifestyle sells them locally and a salesman there was promoting Marantz as their go to line.
As for the surround speakers, I'm currently trying to work a deal on some used BP2X's.
For the front center, I'm still torn as to whether to go with the ProCenter 2000 w/ ProMonitor 1000's or just go with the ProCenter 1000 and ProMonitor 800's. If I understand correctly, I should try and match the front driver diameters (please confirm). I'm just concerned that the ProCenter 2000's height may be a bit much in front/under the TV monitor frame. The 2000 may also conflict with the TV remote control (not sure). I may see if I can borrow a ProCenter 2000 from somewhere to see how it fits. It seems Longbow is pleased with the ProCenter 1000 and Pro Monitor 800's. Decisions Decisions...
Plex, It's been a while but I finally got my Denon AVR 2112CI, Def Tech ProCenter 2000, ProMonitor 1000 fronts and I picked up a used pair of BP2X's. I'm pleased with the system and got a nice package deal from HiDEF Lifestyle in Harrisburg, PA. I have a few questions for the experts:
What is the proper way to set the distance between the front left and front right speakers? I'ver read about the 22 to 30 degree angle off the center listening position to locate the left and right speakers. What's the best method for positioning? Can they be too far apart or too close to the TV? There are three images of my family room about 3 pages back for reference.
Plex mentioned something about keeping the speaker main cable lengths equal. Does this pertain to the left and right fronts or also the center? Should the left and right rear surround speaker cable lengths also be the same? I'm running all the 14 AWG speaker cable from www.monoprice.com in the wall as much as possible. Just curious as to whether I should attempt to keep the lengths equal by adding a coil to obtain equivalent speaker length?
Lastly, I am interested in purchasing something other than a DT sub. Can you suggest a sub from a sub specific manufacturer (i.e. HSU, SVS or other) that would do well with theatre and stereo music? I can't go with the vertical cylinder subs given the WAF. Instead, I have to hide it under an end table or beside the couch or a chair.
Let me know your thoughts, your help is greatly appreciated.
Really If I did I'd only consider the 65's and if was going to spend that I' get 2 more PC2000's. Still the Golden Ear tower's are still in my mind
. I will be sending the 350's back and not sure what to do about the sub.
