I tried the cal and check the settings several times and it is a no go.
If it is the receiver, i have possibly found a replacement for cheap a vsx 921. Is it better than the 1020.
I also play a lot of blurays and hidef mkv files
thanks again
. In the later future I might upgrade the subwoofer . But for now I think it's time to put my bank card away hahahah. I think I did have a def tech overload! But I'm loving it!!!!!
Di you come here before you got the 6's, if so I can't believe anyone who have not tried to get you to opt for the 8 just based on room size. All worked out in the end
and I also initially bought the 600 series set but later upgraded to 800's
so in the end it tuned out great i should have put together a pro 1000 system from the beginning lol i guess it turned out for the better with an additional $400 back on my BB card . Now to make this a 7.1 surround system for the left and right should I pick up 2 pro 800's or should I just get 2 pro 1000's I know there aren't many blu ray movies in 7.1 so I don't know if getting the the 1000's is just over kill or stick to 800's any one have any input thanks.
. The whole 7.1 system I'm just gonna make it 6 def tech pro 1000's keep the pro center 2000 and the pro sub 1000. This way everything is at least the same match. I'm just gonna pick up 2 1000's and I'm set. Everything is set up in a 17x14 room I've been told to set the crossover for the 1000's and the center and sub any were from 80-100hz does that sound right????
