Originally Posted by toddRiffic
Thanks Joe, any and all input is appreciated. I'll be making my choices at the builders design center in a few hours.
I'm usually a bigger advocate of moving the speakers and listening for yourself in the space they're going to be used in rather than strictly adhering rules of thumb. So this will be a bit of a leap of faith.
I will have conduit used as much as budget allows. I assume the larger diameter the better. I will have them add enough slack to the runs for the tower speakers so if I decide to run wire higher up the wall for the pm1000's, I can easily do so.
I'm usually a bigger advocate of moving the speakers and listening for yourself in the space they're going to be used in rather than strictly adhering rules of thumb. So this will be a bit of a leap of faith.I will have conduit used as much as budget allows. I assume the larger diameter the better. I will have them add enough slack to the runs for the tower speakers so if I decide to run wire higher up the wall for the pm1000's, I can easily do so.
You are Toddriffic! Yes, rules of thumb are really just guidelines when it comes to this sort of thing. Trying it out is the best way...but sometimes, you have to make a leap of faith. Good luck and let us know how it goes. Best, Joe
