AVS › AVS Forum › Blu-ray & HD DVD › HD DVD Software › Will audio on Hustle & Flow / Black Snake Moon be at a higher bitrate than blu-ray?
post #1 of 2
Does anyone know if the HD DVDs of these 2 movies will have a higher audio bitrate than the blu ray versions? Traditionally Paramount favors the audio on the HD DVD (1.5mbps vs 640kbps for the Blu-ray) but sometimes they are the same as Blu-ray.
post #2 of 2
Well there is no info on highdefdigest yet about the codec and bitrate, but given Paramount's history it won't surprise me when HD DVD gets DD+ 1.5 mbps and Blu-Ray gets DD 640 kbps
  Back to Forum: HD DVD Software
