AVS › AVS Forum › Audio › Receivers, Amps, and Processors › *Official* Denon 5308 Thread
*Official* Denon 5308 Thread - Page 52
post #1531 of 4900
Originally Posted by no-nonsense View Post
Heck of a nice projector, as far as cables are concerned, I started out using Radio Shack $40 cables, went to Monster cable 600 series, then wound up with Monster cable 1000 series, with each change of cable there was an improvement in color saturation, and video noise has been reduced to the point it doesn't exist anymore, one of the most improved discs is Disneys Pocahontas, which went from visible noise to absloutely no-noise in the picture, which is now so good it comes near to HD quality, just stunning, so you folks can believe as you wish about cables, my beliefs are based upon looking and listening, not on someones opinion, or on a review someone wrote, I borrowed my buddies Oppo player, and while it was better then my old 5900, it didn't compare to the 5910ci, when installed in my system, if it had, I would have saved a bundle
Not sure if you are talking about HDMI cables above, but it's difficult to believe that a digital signal passed along one would end up being different as long as the cable had a reasonable amount of shielding. [I have the pretty Cobalt HDMI cables, by the way, so no cheapies for me either.]
That said, the more shielding, the less likely all the other digi-noise near your other components is likely to mess with the HDMI signals (audio/video), or non-digital signals for that matter. I don't even bother with the AM radio on my 5805 as there's so much digital noise coming from my various components that it's unlisteneable with the generic AM antenna that Denon provided. (But I can say I don't have any digital issues otherwise (unless that's what the cause of my occassional 5910 video hiccup, and I very much doubt that it is); all my cables are non-cheapies (the DenonLink cable seems to be the flimsiest, go figure), but non-crazy too).
post #1532 of 4900
Originally Posted by RickS View Post
Thanks for the comment on the JVC.......really enjoying it!!! I usually stay away from all cable debates or comments but because of the vast difference in price of the HDMI cables IMHO don't see or hear any difference in my system between the high dollar cable and the cheap ones I've tried. I am very picky about A/V quality and have VMPS tweaked RM 40's speakers that are very revealing and use the 5308 as a pre with a 10K Verastarr 6ch amp for the fronts. The projector is also very revealing in the video department. Anyway, I just think IMHO the HDMI cables from 10$ to $300 range don't change what I see or hear in my HT......if I did I would buy all the high end cable needed since the rest of the equipment I use is fairly expensive. Maybe my old eyes and ears just can't notice the difference anymore....
I hardly think that $69 for Monster Cable 1000 series High Speed HDMI cable constitutes an expensive High End product, do you have the optional CinemaScope lens?
post #1533 of 4900
I am a big believer/fan of D-Link, I think it rocks, however that's audio, which doesn't need anywhere near the bandwidth of video, the main difference between the cables seems to be the thickness of the core material, physical examination shows the high speed cables to contain more copper/silver wire than the others, and as I am sure you know, the thicker the cable the greater the transfer of electrons, and the lower the loss, although at the lengths used that doesn't matter, I just think that the higher video frequencies must be stronger with the better cables, and why does the HDMI standards page, say there is a difference in the ability of cables to transfer out either 75 Mhz for standard cable and 340 Mhz for high speed, and high speed cables can carry 1080p and Deep Color, and then say that standard cables 75 Mhz is only good enough for 1080i without deep color, are they not telling the truth?
post #1534 of 4900
I am new to the forum and hope to seek advice from the forum.
I am choosing between the 5308 and the AVP and wondering which one suit me better. I am using a Spectral DMC 20 as pre-amp and Cary 805B monoblocks driving a Watt and Puppy 5. I am using 5.1 at the moment and is using the old denon avp (no hd). I currently do not use balance cable. I wonder if I can use either AV-amp in the following way.
For multi-channel, it is straight forward and I will connect the Front Left-Right out to my DMC20 and other channel to other power amp. I preset the DMC20 in the middle volume and use the AV amp to control volumne.
As for 2-channel output (DVD-audio, concert, and FLAC), can I use the tape out of the AV amp to bypass everything in the AV amp except the DAC and channel it to the DMC20? (I will use two pair of cables betwen AV amp and DMC20)
And if above setup is possible, is there any advantage of choosing AVP over 5308 as I will not use balanced output at all?
Thank you for your advice.
WF
post #1535 of 4900
Hi, well again I do agree that $69.00 is not that much......just saying you can get six cables for that price that don't look or sound any different in my system. I still have a Panamorph lens from my previous projector but will not be using it with my current setup. If I was watching only movies it would be an option but, with 60% of my viewing being HD NASCAR/Hockey/Drag Racing and....many more sports, I am going to stick with 16x9 screen.
post #1536 of 4900
If all you watch is broadcast HD, no wonder it makes no difference what cable you use, do you have any idea how compressed those signals are? in addition, broadcast is only 1080i, they don't have the bandwidth to do minimally compressed 1080i let alone 1080p, the difference comes when watching BLU-RAY MOVIES, or very high quality DVD MOVIES up-converted to 1080, and yes they are also compressed, but nothing like broadcast
post #1537 of 4900
Again, I agree about the compression on HD. I still don't notice the difference on BR from my set top or BR HTPC with the cables either. I'm still
amazed at the picture quality of braodcast HD in 1080i or 720p upconverted by the 5308 to 1080p to the JVC.
post #1538 of 4900
Lets make something clear. Length does matter and there is no physical difference between the newer standard "hi def" cables and any existing HDMI high quality cable. No extra extension, connectors used, etc. The marketing standard is to show testing that good quality cables meet a min standard (voluntarily). Existing non-"standard" cables will meet or in many cases far exceed the "standard." No special sauce. Good cables = good cables regardless of labels. Good cables can range dramatically in price.
post #1539 of 4900
I said the lengths USED don't matter, (anybody using a 100' cable out there? sure that matters, but a 3' to 12' quality cable does not) further I am argueing against the use of standard cables, not for them, I don't believe price determines the quality of a cable, manufacturing processes do so, however I am inclined to believe #1 the written statements put out by the HDMI consortium, #2 my own eyes, which agree with your statement of "HIGH QUALITY CABLES" they come in all price ranges and all reasonable lengths, and what makes you think I am referring to new cables? cable construction isn't a great mistery, they have known how to build cables for at least the last 60 or so years, although HDMI is something new, the method of making cables to handle the bandwidth is not, the term High Speed Cable is just a marketing ploy used to make it seem as if it's something extra special, however since it's used by the HDMI consortium, as well as in the name of the "Ultra High Speed 1000HD Monster Cable" which I bought, I use the term, any other term denoting quality cable would do just as well, now I'm not going to inter the discussion on cables any further, this is supposed to be about the avr5308ci
post #1540 of 4900
... although HDMI is something new, the method of making cables to handle the bandwidth is not, the term High Speed Cable is just a marketing ploy used to make it seem as if it's something extra special...
Then we are in violent agreement, except for the length issue, because impedance in 1080p runs to make a difference at 10' or 25' and it's not boolean all on or it doesn't work. You can get sparklies or green tint combining length and quality. I apologize for perception that you make repeated claims, e.g., best video solution on earth, length doesn't matter, but I'm glad we agree on the substance.
post #1541 of 4900
I said I wouldn't do this, however my personal experience does not extend past an 8' HDMI cable, my buddy says there is no problem with his setup until cable lengths exceed 12', if on the other hand your personal experience with cables as short as 10' is as you say above, then I defer to your experience, there is no such thing as the BEST VIDEO SOLUTION ON EARTH, there are almost always different solutions to the same problem.
post #1542 of 4900
Does anyone know what the difference is between DRC and the Night mode?
They appear to be similar, but they are activated differently in the unit. Is one method better than the other?
post #1543 of 4900
http://www.usa.denon.com/AVR_CI_HDMI...08xx_v0408.pdf
New HDMI specs up for receivers.
Anyone know what CEC does?
post #1544 of 4900
I think DRC is strictly for Dolby tracks and Night Mode can be set for everything. I would try Dynamic EQ, though that might not get rid of loud sounds... if thats what your trying to do.
post #1545 of 4900
It lets you control, say a CEC compliant player connected to a CEC receiver with the receivers remote through HDMI...
Here's one example:
http://www.cepro.com/article/panason...rol_over_hdmi/
You press the PLAY DVD button on the remote control, and the TV fires up, switches to the right input, and plays the DVD. Big deal? It is if you consider that the two-way communications in this case occurs over HDMI.
There is a little-known feature of HDMI called CE Control (CEC) that enables connected devices to control each other using the same HDMI cables that deliver high-definition video.
It's something that people don't know much about, says Steve Venuti, vice president of marketing for HDMI Licensing. But it is a big deal and retailers love it.
The technology, which comes from Philips, has been available for about a year, but has rarely been demonstrated. At CES, Panasonic demonstrated CEC at both the HDMI pavilion and Panasonic's own booth.
In one of the demos, a user plugs a video camera into a TV via HDMI. The TV automatically switches to the camcorder's input and displays the content. The user then controls the camera through the television via remote control. No extra programming, control cables, or IR repeaters are required. Theoretically, users should be able to enjoy this and similar scenarios if all HDMI devices on the network are CEC compliant.
Panasonic, which has built additional software on top of CEC, calls its technology EZSync. In addition to performing basic CEC tasks, EZSync products enjoy an extra level of functionality. Press the EZSync button on a Panasonic remote, and a menu comes up on the television screen.
Select HOME THEATER, for instance, and the TV's own speakers mute, the Panasonic surround-sound system fires up, and volume is now controlled through the receiver. Turn the receiver off, and the audio automatically switches back to the TV speakers. Panasonic will incorporate CEC and EZSync into every new A/V component that includes and HDMI connector.
post #1546 of 4900
Here's one example:
AHHHHH Cool! Thanks FM!
post #1547 of 4900
Have a bit of a financial situation going on...
If anyone is looking for a lovingly cared for, 4 week old 5308, please PM me
post #1548 of 4900
NEW ISSUE....
I have the latest firmware installed on my 5308.
I also have successfully backed up my setting on the WEB Control through my browser, thanks to the help here
I have a successful wireless connection via the network settings.
I can stream internet radio.
Now I get the message on the screen ALL THE TIME..
Update retry
Connection fail
Seems that no matter what I do the screen on the 5308 say's that message all the time (unless I go into the GUI).
Has anybody heard of this?
I already did a hard re-set and it still didn't clear up the message.
post #1549 of 4900
Originally Posted by blownaway View Post
NEW ISSUE....
Update retry
Connection fail
No I havent seen that issue. Since you have already tried a Hard Reset I would call Denon support at this point
post #1550 of 4900
Anyone use the Denon 5308ci with a Harmony one. If I hit the menu button it brings me in the menu but the up and down arrows dont work yet left and right does
post #1551 of 4900
I have exactly the same problem, and I can't even get the harmony to 'learn' the up and down commands using the correct buttons. I had to create separate up and down command buttons in the LCD screen menu at the top.
I thought I had somehow broken my buttons , but looks like it's a Harmony incompatibility issue.
post #1552 of 4900
Thanks, with the help of this forum this problem was been resolved!
I just put the error massage in an AVS search and found what worked for others.
I think it was caused by shuting the Denon off while it was "updating" (loading more like it). I was loading my settings via the web contol, wirelessly and it crashed (or ?) and just wouldn't finish loading so I had no choice but to turn if off.
post #1553 of 4900
I'm using a Harmoy remote and my up & down buttons work just fine.
Be sure to download the latest Haromony software update if you haven't done so already.
One thing that I haven't figured out with the harmony is how to get all the buttons on Harmony to duplicate what's on the Denon zone remote.
For example you can't tune internate stations or even open up the GUI using the Harmony.
Have you figured out how to do this?
The Harmony has replaced all my other remotes except the Denon zone remote.
post #1554 of 4900
I can open the GUI thats where my problem is once in the GUI (by hitting the menu key) I can go left and rigth but not up and down
post #1555 of 4900
In Devices, choose Settings, then Customize Buttons, then change the up and down buttons to look like this:
post #1556 of 4900
GREAT !! that fixed it and I moved tune up and down to the middle up down button
Thanks again
post #1557 of 4900
Worked for me too - many thanks !!
post #1558 of 4900
How did you open up your GUI?
Do you have to be in the mode where the 5308 is the "device"?, then you push menu key?
post #1559 of 4900
yes ,You have to have it choosen as a device
post #1560 of 4900
The denon A1HD-5308 has been reviewed in the hi-fi news UK edition
It gets top marks they say it is better than the competition. Yam and £1200 cheaper.
They rate the amps at 2x200 watts 8-ohm 2x285watts 4ohm driven.
5x160w 7x140w 8ohm. Just thought I would let you guys know.
