Originally Posted by fmalczewski
Not really following what it is you're trying to do, but my setup with a 5910ci and a 5805mk2 receiver is that DenonLink3 does the sound and HDMI does the video. You shouldn't need to do any of that other stuff if your settings are geared toward that goal. (Make sure the 5910 is set to output DL3 and your 5803 has DenonLink set as its audio input and your HDMI as its video input (I don't know how that's done on a 5803.) I do switch all of my HDMI thru the 5805mk2 to a single HDMI hookup in my TV (and have my TV audio turned off, fwiw.)
You understand correctly - that's exactly what I'm trying to do. I have the 5910A hooked-up as you specify. The one difference is that you have a 5910ci and I have a 5910A (that actually still says 5910 on the front). I had read that only certain 5910A's had this problem. Unfortunately it seems like mine does. I'd say I should have waited a few more months to purchase but I've gotten 7 years of great use out of the 5910. This is the first bug. I'm going to try a processor reset tonight as well.
For me, the result of your setup, connected exactly the way you specify, is good video and audio that seems to be roughtly the center channel audio in the right speaker and the left channel being one of the other channels (it varries). Remove the HDMI and everything is correct. Disable DenonLink in the 5910 menu and the multichannel is great over HDMI (except no SACD).
I have a follow-up call to Denon this evening to discuss when I'm at home.
