Originally Posted by
robbroy
There is not enough room in the box for the rear mounts.
Those are probably in the same shipment as box 2 of X.
Fair warning: you will need help from a friend to hang these. And when you think you have the teeth tight enough around the rubber ball on the mount, keep tightening. I woke up the next morning with the speakers sagging against the wall and had to start over.
-Robb
Thanks for the info I will not be doing it by myself...
That's just it (see bold) the speakers are coming in 2 shipments from 2
different shipping companies...UPS & BaxGlobal.....the UPS shipment contains 5 boxes (5 speakers, correct?) & the BaxGlobal contains 1 box which has to be the sub due to the weight of the box.
Unless they packed the mounts in one of the speaker boxes I am 1 box short...unless two of the speakers come in one box.
I hope this made sense...
- Cam
