I have the Motorola dtc-3412, which I am told is an older Motorola box, I want to record some shows in hd off it, in whatever fashion is best or easiest.
I see folks doing firewire to xp, and I see the snapstream boards for pcs, the fusion usb hdtv recorders as well.
My question is, should I get a newer or different model box from comcast?
If not, what is the best way to do this...if I could get a one stop thing with either a fushion or snapstream product on a pc or the firewire to xp that would be great?
The ultimate goal being to capture the shows in 1080i when they are sent 1080i AND burn them to a dvd with a codec to play BACK at 1080i as well.
I have just spent 3 hours doing searches on the board reading peoples experiences and realized there are too many posts to be able to read them all.
I build my own pc's so I am pretty pc literate.
Assuming the flag is disabled 5C, can I record the 1080i from one of the ports on this cable box?
Thanks for the help folks!
