AVS › AVS Forum › Blu-ray & HD DVD › HD DVD Players › VERSION 2.0 FIRMWARE FOR THE A2, XA2, A20, A2W, and D2 (Fixes Chroma Bug!) With link
post #1 of 682
I just updated my Toshiba HD-E1 from 1.5 to 2.0/T22M. No idea what the improvements are.
Here is a link to official downloads:
http://209.167.114.38/support/ceg/downloads/index.asp
post #2 of 682
Digital Video Essentials works properly now. HD Chroma bug is fixed. Woohoo!
post #3 of 682
Wunderbar.....
post #4 of 682
And here's proof that the chroma bug is now fixed, photographs of my LCD screen displaying a test pattern in Digital Video Essentials. Red in the opening titles of 12 Monkeys and Total Recall looks much better.
post #5 of 682
OW! My eyes hurt now!
post #6 of 682
My HD-A2 is updating as I type this. Don't know to what version yet. I'm currently at 1.6.
post #7 of 682
A few of us here in Australia have downloaded this tonight. Not fully tested yet, but one user reports that it looks as though it now fully supports 24fps. Will confirm tomorrow.
Boot time is slightly faster.
Apart from that, I cant see much else thats new.
post #8 of 682
E1 @ 11/38 and plodding along !
Has enyone checked for SD DVD playback? ie region free now, if we should be so lucky
post #9 of 682
It's also out for the HD-A2, HD-A20 and HD-XA2
http://www.tacp.com/tacpassets-image...d2firmware.asp
post #10 of 682
cyber, let us know if the boot times are faster?, that was a big topic for the new firmware.
post #11 of 682
Thanks slimm, I didn't realise it was over there already. I thought us Aussies were special for once!
post #12 of 682
You are special, you were the first one to post
post #13 of 682
I'm updating my A2 as we speak. I may see if this 2.0 firmware fixes the HDMI->DVI black crush problem.
I'll report back later.
Chris
post #14 of 682
2.0 should add something. I remember 2.0 added THD to the 1st gen units.
post #15 of 682
Seems about the same to me
post #16 of 682
Is it absolutely necessary to do an "Initialize" after the update in order for the firmware changes to take effect?
Chris
post #17 of 682
Children of Man 'Disc not DVD error' now gone.
Disc starts normal now.
post #18 of 682
THERE IS NOW A VERSION 2.0 FIRMWARE FOR THE A2, XA2, A20, A2W, and D2 located on the Toshiba support page...
I downloaded to my A2 minutes ago.
post #19 of 682
I just updated my A2 from 1.6 to 2.0. I did not do an "initialize" after updating (not sure if you have to or not).
Boot time and disc loading time does not seem to be any better.
Tried HDMI->DVI again. With 1.6, I had black crush to my Sony KF50-WE610.
I still have black crush. King Kong is WAY too dark. DVE pluge pattern doesn't even display the blacker than black bars. I cranked my brightness up 20 "notches" and couldn't see anything.
Everything still looks good through Component, which is what I've been using and what I'll continue to use, I guess.
Not sure what this update adds in terms of major functionality. I would think it must be something significant to warrant the 2.0 number.
Chris
post #20 of 682
Checked for 24p support on Euro XE1. Projector still reports 60Hz.
post #21 of 682
What does this fw fix/enable?
post #22 of 682
Sony Pearl still reports 1080p/60 as well.
post #23 of 682
This firmware looks like it was designed for Blood Diamond that is coming out next week...a lot of network fixes
post #24 of 682
duplicate
post #25 of 682
Is there an ISO somewhere ... or do you need to ehternet download it?
Link?
post #26 of 682
Chris
No, just a restart/reboot which happens every time you power on.
post #27 of 682
Since the Mods want this thread to be used, how bout changing the title to encompass all gen2 players.
post #28 of 682
There's a Film option under Picture Mode that wasn't there before...
FWIW -- My A2 included that option with both rev 1000 (original) and 1.6.
post #29 of 682
Chris
Hi Chris,
This update didn't address the incorrect colorspace problems, at least not on my setup.
Larry
post #30 of 682
OK, thanks, thought it was just video and auto before. I'll delete that part of this post.
  Back to Forum: HD DVD Players
