Originally Posted by
rwestley
In your case I would use as Sfhub as suggested the inexpensive Monoprice manual switcher. It is manual and has no chips in it so it works with everything I have ever tried with it. It is easier to use than the $5 alternative you have suggested and it costs only about $18. As an bonus a easy modification can be made making it into a manual splitter.
good suggestion, but that would render my $5 coupler investment obsolete
rwestley
I am also wondering if something else is causing your problems. Did you swap out cables. Once I found one bad cable that was causing all of my problems. Each cable has 19 connectors in it and one bad connection in the cable or in the internal connector on your equipment can cause havoc.
I did try several different cables. I have two different HDMI/DVI cables, and two different HDMI/HDMI cables, so I was able to swap out and individually test each cable. Also, the cables all work fine with the coupler.
