Originally Posted by nlsteele
Somebody (I think Slare) posted a photo of this review (about a page back) if you wanted to save the magazine-style copy for yourself (I save everything I can find on my gear out of some odd sense of provenance).
Do you find that it actually makes a difference? I still can't get my head around replacing gold-plated jumpers with copper. I've pulled a few and don't see any wear whatsoever, nor corrosion, so maybe it's 6 of one, half-dozen the other? Or do you really get a timing difference in transients?
Gold plating actually does not make a particularly good contact. It's resistant to corrosion and so should not degrade, but good old copper and/or nickel make a better connection.
That said, many of the shorting straps used by JBL are not gold plated and there have been reports of poor connections resulting in degraded sound. Tightening can also result in the plating being scraped through to the metal underneath.
filecat13 likes to hide his copper connectors behind the shorting straps. I just toss the straps in a drawer and use plain old zip cord. YMMV
