AVS › AVS Forum › Audio › Speakers › The OFFICIAL JBL Owners Thread
The OFFICIAL JBL Owners Thread - Page 469
post #14041 of 14062
Originally Posted by DNA02 View Post
just need some advise to decide which speaker I should get, currently I'm using the JBL Cinema Sound 5.1, saw a JBL NL300 and Energy CF-50 on sale right now, want to upgrade my front speakers, which one is the better choice?
Since this is a JBL thread, guess what we're likely to recommend? Nonetheless, can you be more specific about the Cinema Sound system you're using? 300? 500? 6100? or????
post #14042 of 14062
Originally Posted by waltie View Post
Rdgrimes: thank you for your helping. Since my center speaker is the S Center, isn't there any possibility of sonic unmatching? I was thinking of changin the S Center for the LC2, but this speaker is too high to fit in my rack. Also I think the sonic difference is more likely to happen by not keeping the center speaker in the same line. Is that correct?
Hi waltie!)
Keeping the tweeters within 18" of each other vertically, across the front horizontal soundstage is best if you can at all rig it up that way.
I can't comment on your S center vs. the EC35 center, but I did recently upgrade my ES25C to an LC2 and very much like the improvement!
Better power handling, better midrange and bass (low frequency extension), and clearer dialog.
The only thing I was unprepared for was the LC2's lesser efficiency - which is odd because its spec'd at 92db sensitivity, whereas my older ES25C was supposedly a 90db speaker - but the LC2 needed some level boosting from my previous settings and seems to consume a lot more power than its efficiency rating would suggest.
The highs and mid highs of the LC2 are similar to my other ES series speakers which is good.
Good luck!
post #14043 of 14062
I'm using the 500 series right now, also looking at the KEF Q900, is that a good speaker, will it match the center I have or do I need to change the center too if I got the KEF?
post #14044 of 14062
From my experience auditioning KEF....they sound nothing like JBL. From the KEFs I've heard, I would not want them for free.
On a rare occasion mixing brands of speakers in one system might work. But 99% of the time it sounds like crap.
post #14045 of 14062
i put up my JBL voice and JBL Balcony up on sale on amazon if anyone is interested. those Balcony Venue speakers are great for Zone 2 or front height if you're looking for some additional soundstage. smile.gif
http://www.amazon.com/JBL-Series-Center-Channel-Speaker/dp/B000EZ764E/ref=sr_1_1?ie=UTF8&qid=1368651473&sr=8-1&keywords=jbl+voice
http://www.amazon.com/JBL-Series-Balcony-4-Inch-Speakers/dp/B000FBPH9S/ref=sr_1_1?ie=UTF8&qid=1368651490&sr=8-1&keywords=jbl+balcony
both ship free with amazon free super saver.
post #14046 of 14062
Just looking for some advice on my setup, JBL E30 Fronts, EC25 Center, N24 surrounds and E150P sub.
I've been doing alot fo reading on on the speaker setting SMALL vs LARGE and can't seem to find a right answer. For the past 7 yrs ive always used the SMALL setting with Sub set to YES. My Amp is a Pioneer 1021 and when i run MCACC it sets my E30's to LARGE with a xover of 80hz. I'm reading on different forums that the E30's could in fact handle the LARGE setting with the subwoofer set to PLUS.
The reason i'm looking into this after 7yrs is 1. the itch to tinker 2. I dont feel i'm getting enough bass. The other day i turned volume knob on the sub from half to to in between full and half and i liked the extra rumble however thats going against the MCACC calibration.
Any body have a similar setup that can provide some guidence? My room is about 12 x 12 with a wall only on the right side. I sit about 9.5ft away from the LCR and 10ft away from the sub. the sub is connected using LFE.
Thanks for any advice.
post #14047 of 14062
I have the studio 1 190s up front set to large and 2 subs, one under each side table on the side of the couch. Reversed the phase on the subs which cleared up the hollow bass issue. The 190s are set to large and the subs are set to plus with a 50hz crossover point. I am still playing with the crossover point as 80 seems to have a smoother transition to the low end. So to answer your question I am running it as you such. But I would use that driving force of tinkering to find what works best in your room smile.gif
post #14048 of 14062
The difference in the E30 and 190 is bookshelf and full range tower. They need different settings.
As for MCACC, like any auto setup program, they don't always work as they should.
When you get a setting of "large" for limited range speakers, you know it is wrong.
Set the E30 to "small" and the XO to 80.
post #14049 of 14062
I would recommend that you keep your E30s set to "small", and with a 80Hz crossover to your sub. (Odd that your AVR would designate them as "large" - and then set a crossover!).
A good rule of thumb is to set your speaker's crossover point to the sub woofer at roughly 20Hz to 30Hz above its rated low output (to -3db or so), which then allows for a good roll off, doesn't over-tax your speaker's capability, and makes the most of the sub.
Those speakers are good down to about 55Hz (at -3db), so I would never designate tham as "Large", even though it might sound like you could...
post #14050 of 14062
Thanks for the excellent responses. I will set the speakers to small with an 80hz crossover and rerun mcacc.
Any idea what subs rated low output is? Amazon states frequency response curve is 27hz low pass xo setting. Is 27hz the rated low output?
post #14051 of 14062
What about a very similar setup? E50s instead of E30s, and an EC35 instead of an EC25. Same sub (E150).
I'm driving them with an old HK AVR435 and can't remember if the AutoEQ set the E50s to small or large. This has sparked my mind to go check!
They are still bookshelves but have a little more oompa than the E30s.
In the meantime I've also been mulling over an upgrade to L890s in the front, an LC2 at center and L810s in rear. But for now I want to make sure I'm getting the most out of what I've got.
post #14052 of 14062
Forget the L810 and keep the E30s or E50s for surrounds.
post #14053 of 14062
That 10" sub is rated for audible output down to 27Hz, but JBL doesn't indicate on their site what its roll off is.
Pretty good response for a 10"...
After you re-run your room correction, go into your AVR's audio/speaker set up menu and make sure the E30s are set to "Small", and with a 80Hz crossover - regardless of what the room correction software sets them at.
If they're anything like my ES30s, they're terrific performers!
post #14054 of 14062
Thanks for the response, I will try that now and report back. What is the general consensus on where the volume knob on the actual sub should be set at?
post #14055 of 14062
50% max. But better to be less. This leaves plenty of head room.
post #14056 of 14062
I believe the manual recommends setting the level to the '11:00 O'clock position', and use the LFE input, and set the crossover to the maximum.
Then the room correction software should do the rest.
(Say?, doesanyone know if the AVS Forum has a spell check function anywhere that I'm missing? I don't see it but it would be nice to be able to self-correct messages before submitting...).
post #14057 of 14062
that's usually a browser addon?
post #14058 of 14062
Thanks for the responses regarding the sub volume knob. That's how I will set it up
post #14059 of 14062
post #14060 of 14062
Just got an EC35 in the mail from ebay. The right mid was falling out of the cabinet, only held in with one screw. Found two screws in the box. Seller listed it as mint condition. Some assembly required? Don''t know if I should keep it and have the seller cover the price of a replacement mid or just send the entire thing back. Otherwise the speaker is in good condition.
post #14061 of 14062
I assume the mid is damaged? So you can not just put it back with some more screws?
post #14062 of 14062
Common in JBL speakers is that the mid-range will have an isolation "can" behind it. Make sure that is still firmly attached to the rear of the baffle. If so the only question is whether the screw holes for the driver are intact, and the driver itself is too. It's unlikely that the driver could just fall out without some other type damage being involved. If there's no damage to the packing material, you have to wonder if it was like that when shipped.
  Back to Forum: Speakers
