I have a combo 2-channel/HT system in my basement. The floor is cement (covered by commercial carpet). It is very uneven, so leveling my Thorens TC-166 MkII (all stock w/ Ortofon Super OM-10 pickup) is a serious challenge. I need to compensate for an inch or more of tilt my rack has as a result of the uneven floor. I have been using stacked coins wrapped with tape, but I was hoping someone would have a more elegant, but still inexpensive, solution for this issue. Please post any ideas you might have. Thanks!
Turntable Leveling Problems - Help Requested!
AVS Top Picks
post #2 of 41
6/26/07 at 1:20pm
post #4 of 41
6/27/07 at 2:46pm
post #5 of 41
6/27/07 at 7:05pm
post #6 of 41
6/27/07 at 7:23pm
post #7 of 41
6/29/07 at 6:12pm
post #8 of 41
6/29/07 at 9:03pm
post #9 of 41
6/30/07 at 2:19pm
post #10 of 41
6/30/07 at 5:00pm
post #11 of 41
6/30/07 at 9:12pm
post #12 of 41
7/1/07 at 10:20am
post #13 of 41
7/1/07 at 10:35am
post #14 of 41
7/1/07 at 3:43pm
post #15 of 41
7/1/07 at 8:49pm
post #16 of 41
7/1/07 at 9:31pm
post #17 of 41
7/1/07 at 11:10pm
post #18 of 41
7/2/07 at 5:57am
post #19 of 41
7/2/07 at 6:43am
post #21 of 41
7/2/07 at 11:00am
post #22 of 41
7/2/07 at 12:57pm
post #23 of 41
7/2/07 at 2:02pm
post #24 of 41
7/2/07 at 3:53pm
post #25 of 41
7/2/07 at 5:05pm
post #26 of 41
7/2/07 at 5:06pm
post #27 of 41
7/2/07 at 5:13pm
post #28 of 41
7/2/07 at 6:04pm
post #29 of 41
7/3/07 at 7:07am
post #30 of 41
7/3/07 at 7:09am
then I too would worry about uneven wear on the bearings and pivots etc, but if you can't even visually see that it is tilting, you only know from a bubble level that it is (say, 5 degrees or less), then I think the pertinent factor is that the tonearm calibration (balancing, subsequent tracking force application, and anti-skating force) must be set while in this slightly "tilted" position. And of course re-calibration is a must if later then moved to any other shelf.
Happy 4th everybody!
