I bought a Pioneer VSX-516 to put in my pool cabana to power some rock speakers by the pool. I ran 14 guage landscape wire (the kind you use for lights) as my speaker cable. I hooked up two 150 watt rock speakers and everything was fine until halfway through my sons party when one blew (lost the woofer). An hour later the other went. So I figured defective speakers since I am only pushing 100 watts to each speaker. I bought a different set of rock speakers to replace those and tried again. The new speakers are only 125 watts but again I figured I should be fine. After about 20 minutes of testing, they both blew (again lost the woofer). I know I haven't hooked anything up backwards so is it the receiver, the wire, the speakers, all of the above???? Please HELP ME.....Thanks
Desperately Need Help (keep blowing speakers)
AVS Top Picks
post #2 of 20
6/26/07 at 6:22pm
post #4 of 20
6/26/07 at 6:34pm
post #6 of 20
6/26/07 at 7:36pm
post #8 of 20
6/26/07 at 8:33pm
post #9 of 20
6/26/07 at 9:08pm
post #10 of 20
6/27/07 at 8:30am
post #11 of 20
6/27/07 at 8:53am
post #12 of 20
6/27/07 at 9:02am
post #13 of 20
6/27/07 at 9:42am
post #16 of 20
6/27/07 at 2:12pm
post #17 of 20
6/28/07 at 12:19pm
post #19 of 20
6/28/07 at 2:40pm
post #20 of 20
6/28/07 at 2:53pm
I'm guessing your not wanting to spend a lot? They are very efficient. My guess is your turning your receiver up so far that it is clipping and blowing the voice coils on those cheap rock speakers.
