I am trying to transform my basement into an HT and had a couple of questions about how to ideally set it up. I read the FAQ and did a couple of quick searches and while I did find out some good information and answers to most of my questions, a couple are still outstanding and I am hoping someone here can help me with them.
I want to get the best possible digital cable TV signal to an XGA projector (no HDMI input). My thought is that if I use the composite lead from my current cable STB (small 5*4*1 kind) into a DVD Recorder, it can somehow upscale the signal to 480p and send via component to the PJ. I know the PJ can de-interlace and scale the signal itself, but I was wondering if a DVD Recorder would do a better job at de-interlacing since it also de-interlaces DVD's. With that, here are my questions:
1) Is this something DVD Recorders can even do?
2) Will it give me better PQ than runing the cable via composite straight into the PJ?
3) Should I just try to get a SD STB w/ S-Video or Component output?
4) If the DVD Recorder has a digital tuner, would I even need the STB anymore (would OnDemand still work)?
5) Would the digital tuner also be able to pick up local HD channels OTA?
6) Is a DVD Recorder the best solution to accomplish this and if so, what models would you recommend?
7) If the DVD Recorder isn't an option, would an HDTV STB, be able to send the SD cable content to the PJ in 480p?
As some of these questions are cable related, I may be in the wrong forum so if I am please let me know. I was just thinking that if the DVD Recorder was the best way to go, many of you would be using some sort of cable setup with it. Also, I don't need to be able to record in 480p (as it looks like that is impossible), just send 480p to the PJ.
I would appreciate any help on this. Thanks!
