post #1 of 1
I've had the MX-3000 for awhile now and finally bought the RadioRa Home Theater Package. I installed everything and the system works great. I have the MX-3000 setup perfect. All the lights come on and off perfect whether using the RadioRa remnotes or the MX-3000.
The dimming feature works perfect with the RadioRa table top master control as well as the Grafix IR remote. The dimming feature however works very poorly with the MX-3000. It seems the way the repeating button sends the raise or lower signal gets messed up and is not sent correctly.
Does anyone have any idea how to adjust it work correctly. I've tried to set the button to repeat once as well as 3 times when pressed. Has anyone gotten this to work smoothly?
