AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Best Playstation 3 compatible 46" 1080p Monitor?
post #1 of 8
I have been doing research for the past 3 days and have been able to come up with a clear choice for 46" - 50" 1080p TV with HDMI & 1080p over DVI.
Pretty much all TVs seem to have HDCP issues or backlighting issues.
Can anyone mention a tv in this category which they would recommend without reservation.
I have been very happy with my Westy 37" 1080p but I have read that the newer models and the 47" have a ton of problems...
post #2 of 8
Check out the Samsung 4665f or 5265f, and the Sony 46XBR2 or the 52XBR2.
post #3 of 8
i agree. or if you're on a budget, the Toshiba HL167 sets may be a little cheaper and i've heard good things about them. also, the Samsung 61F series will probably be a bit cheaper than the 65F series. the 65F has a clearer screen, which will give you better picture, but also glare in brightly lit rooms.
also consider Sharp's 1080p sets.
keep in mind that not many HDTV's have DVI ports anymore.
post #4 of 8
Thanks for the responses, I'd like to spend about $2k.
post #5 of 8
I've played Virtual Fighter 5 on the LC-46D62U at Best Buy. It was amazing! Almost 3D-like on my first viewing. If you can find a set without banding I would suggest it.
post #6 of 8
I would highly recomend the Syntax Olevia 747i . A great set for the $$$$ with great hd & sd pq . Plus it can handle 1080p/24 from the ps3/blueray and has the best 10-bit vp chipset,Realta HQV, integrated for dvd-quality sd and the best hd clarity unlike most other brands/sets out there.
post #7 of 8
booneabal,
I was in the same position as you up until today when I purchased a new Samsung LN-T4066 (1080p) from BestBuy for $1899 (pre-tax). It's the newest model line from Samsung (LN-TXX66), which features a 15000:1 contrast ratio, which is simply stunning. I had a friend purchase a Sammy LN-T4665 from BestBuy a couple weeks ago for ~$2800, if you wanted an idea of how much a 1080p samsung would cost.
post #8 of 8
I have the SONY KDL-46V2500 and I think its great.
