The CopperFields Cinema - Page 7
post #181 of 1201
Hey Scott:
I did a quick search for the great lamps/cans you found but could find them anywhere. Wonderful idea for your HT (maybe mine too ), do you have a link or site?
Dave
post #182 of 1201
Dave
The cans I got at lowes they are the really small 3 inch with the GU10 halogens in them
Send me a PM dave with your email and I will send you the Ebay link to those bulbs
post #183 of 1201
Using those cans on the front of my screen painted black, these might work for me as well. Looking at the remote they seem to do quite a bit, do you know if they can be dimmed by a dimmer switch? i.e. Grafik Eye
post #184 of 1201
W00ley:
Those are SO COOL! I need to find some for the front of my screen. I was planning to steal the idea from someone who stole the idea from Art's most excellent theater.
I have 5 cans shining down on my screen and 2 cans behind the AT screen to show off the speakers (the way they do it at a good IMAX show) in my plan. These cans are just the ticket!
CJ
post #185 of 1201
Oman
Yes they can be dimmed from the switch or the remote has dimmer settings on it also They are also GU10 bulbs I do think they come in other styles but not real sure
post #186 of 1201
CJ
the can lights I got at Lowe's they are the Utilitech 3" GU10. The bulbs are from a Ebay seller LEDbulbs.biz If you want the link PM me your email.
I found that the IR on the bulb mite have to be hooked into another IR setup. when I tested it you had to be pretty straight on to get the remote to work. Since I have not installed these yet I wont know until then
post #187 of 1201
Thanks, W00ley. I'll try to find the bulbs online.
I have the same cans you mentioned for over my bar area. I haven't installed them yet, as I'm going to do the remodel install, as it looks easier than fooling with those silly brackets (and attempting to cut the precise hole in the drywall around the installed fixtures). The problem that I have for using them in the theater is that they are not IC rated (with the incandescent bulbs). I want to insulate the ceiling of my theater fully and was planning to have the cans IC rated. I don't want to build a box to put them in, as I'm not sure if I can make room for the boxes in the ceiling (but I will if that's the only option).
Was IC rating an issue for you?
post #188 of 1201
W00ley:
I have a question concerning conduit for wiring. Post #177 shows some photos where you are using the blue flexible conduit that seems to be connected to electrical boxes. Why are you using conduit? Are you going to use conduit for speaker wiring too? What is the benefit of doing so?
I'm pulling wire this weekend and was wondering if I need to change gears and use conduit for parts of it. I am going to use conduit for the speaker wiring, though I'm not really sure why.
Thanks for the help.
CJ
post #189 of 1201
CJ
Heat is the issue with those non IC little cans if you run a LED bulb instead of the halogen I don't really think its a issue since the LED"S do not put off any real heat. You can put your fingers on the face of them and keep it there try doing that with those Minnie halogens. and the LEDS come in a ton of colors or plain old white I will post some photo's of my light install soon
I have not pulled any of my wire yet I am planning that shortly. I ran the conduit just for the fact if any of my wires be it speaker-sub-IR goes bad or I want to add a wire I can just pull out the bad and pull in the new. I wish I would have just run two one inch orange smurf tubes to the front
I have learned alot along the way of the things I would do a bit different. I planned to use wall plates but since I am using a acoustical transparent screen I'm just going to run my speaker wires from source to speaker
It would really suck to do all that work and have one speaker wire or sub cable go bad and not have a way to get to it without tearing up your drywall
CJ good luck on your build and keep asking questions it only helps you in the long run
post #190 of 1201
Hey Scott, have you picked your rear surrounds yet?
I am diggin' your color scheme, keep it up!
post #191 of 1201
Judson
Not yet but I am thinking seriously about those Jamo's you suggested. I will make a decision in the next week or so.
post #192 of 1201
Hey Scott, thought I'd drop by and see how things are going. Carpet looks great. Keep those pics coming!
FWIW, I looked seriously at the Jamo line before I bought the Monitor Audio's. They make very nice gear.
post #193 of 1201
Evening All
Well I finished up framing the equipment room and the new closet for the bedroom today. Tomorrow I'll finish up re running my electrical wiring and start hanging some drywall back up I think this layout works alot better then the way I had it set up the first time. Now to decided if I just want to build my own rack or buy a middle Atlantic rack.
component room roughly 9x10
Closet is roughly 4x9
Looking out into the 14x14 bedroom
In the spring I will need to cut into the foundation and install two large Egress windows one for each bedroom. I mite hire some pro's to come out and do that
post #194 of 1201
Scott, not using pressure treated lumber for the bottom plates?
post #195 of 1201
Nope. I should have but did not.
post #196 of 1201
W00lly,
Any new pics? Maybe one with the chairs on the new carpet so we can get an idea of the final results
Cheers
Calvin
post #197 of 1201
Calvin
I will post a few later tonight
we are going out tomorrow to look at some fabric for the top half of the room with our carpet sample. I hope we can find something the Wife likes
post #198 of 1201
W00ly, a fellow Omaha AVSer here. I have the same steel beams in my basement. How did you box them in?
post #199 of 1201
Hey Lyman
I used 3/4 OSB and glued it to the beam with liquid nails. If you go back and look through the photo's on page 1 #25 you can see where I glued on the OSB. I did this before drywall so I could screw the top of the OSB to the 2x8 the builder glued to the top of the beam and then ran a generous amount of the liquid nails along the bottom and clamped it tight left it for a good 2 days before the clamps were removed. for the bottom I did pretty much the same thing but screwed a 2x4 nailer to the wall page 3 #71
post #200 of 1201
Here you go Calvin
here are my $1100 set of chairs man that was a steal. I love finding awesome deals when you have the cash laying around
Now to get started on my wall treatments also I painted the ceiling black for the mean time as later on down the road I will be doing a star ceiling
post #201 of 1201
Screen wall next
Can't wait to put my SmX 12' 2.35:1 screen together. I have had it for over 3 months now and I have been itching to take it out of the box
post #202 of 1201
Hey Lyman
Thanks! Awesome build, BTW.
post #203 of 1201
Lookin good Scott! Love the chairs. I think your color combo is going to be really nice.
But I thought I saw a little glitch in the ceiling paint in one of the pictures? Maybe you should roll it again.
post #204 of 1201
There's alot of glitch's as I didn't even finish the drywall The one you see up front is a opening to conduit for the fiber optic cable for the star ceiling.
Craig you don't know how pumped I am after dragging the chairs in there last night. I am going to work full steam ahead to get this thing up a running ASAP
post #205 of 1201
I know the feeling buddy. Keep pushing!
post #206 of 1201
Well I spent about 2 hours in a fabric store today that supply's upholstery and drapery fabric. When I walked into this store I could not believe how many fabrics they had - thousands. Needless to say many were way out of my price range starting at $20 a yard on up I brought a few home and the wife and I chose this one
post #207 of 1201
Looks Nice
Check out the drape section at JC Penny. You might be able to find a similar pattern at a cheaper price (if you don't need to go with a larger cut of fabric than a drape panel). I got mine below what the fabric store would charge for the fabric alone. My drapes happened to be on sale...Plus sometimes if you buy something... they will print out a %off coupon that you can use for the next purchase. I bought one valance and the coupon printed out...and then bought all the rest of my drapes and valances with the coupon!
-Cam
post #208 of 1201
Wow Scott, very nice. How do you plan to do your walls? Is that fabric only on the top, top to bottom, etc.
Judson
post #209 of 1201
Hey Judson
I plan to go with black about 4 foot up then the rest the green material. I am also going to do some columns of some sort in between the sconces. I am heading out to place the fabric order now. I am also installing those LED's today I will try and post a little video later tonight of the them in action
post #210 of 1201
That is gonna look awesome!
