Jamis
that Panasonic projector should be bright enough if you watch in total light control. I am using a Mitsubishi hd1000 its 1700 ANSI lumen's. Its a bit dim now as I am getting close to 2000 hours on this bulb but when I first got it it killed my eyes it was so bright. I am due for a new bulb now.
right now I am using a CAVX lens for my strtch and when the lens is in place it does dim the picture a bit when in use. but other then that I am glad I whet with a CIH setup
or two
If you decide to do a stage it does not have to be a real complicated design just enough to keep the kids and others from putting there hands on the screen. I just used a heavy mil plastic sheeting to keep the sand in.
so we decided after leaving the theater that from now on we will wait for all movies to come out on Bluray and enjoy them in our own Theater in ultra hi-Def
