The CopperFields Cinema - Page 3
post #61 of 1201
W00lly,
They both look pretty good I'm leaning towards the molten copper though (although both would look great I'm sure)
Good luck
Calvin
post #62 of 1201
I like all 3 we will see what we can come up with as an accent color and match them up. I have more Gom samples coming.
post #63 of 1201
I see the view count going up but nobody posting there thoughts on my carpet choice's. I am now having second thoughts maybe I should look some more. The more I look at the pattern the more I think I want no pattern. There are just too many choices at the carpet store
I like the grey. Looks great and gives you lots of wall fabric options.
post #64 of 1201
Thanks Craig
Hey Craig where did you get your wet bar cabents from I really like that look
post #65 of 1201
Thanks Craig
Thanks! They're KitchenCraft "Sheffield" in Cherry (http://www.kitchencraft.com/door_styles/sheffield.aspx#). We're Direct Buy members so we got them through the club. Fantastic deal.
post #66 of 1201
there are no direct buy show rooms in my area closest is springfield MO
post #67 of 1201
I prefer the grey pattern too.
I'm planning to do the same exact SMX screen size, so I'll be anxiously watching your progress! What's your front row seating distance?
Great work!
post #68 of 1201
Banshee
Front row seating is going to be between 13' & 14' we will see once I get the stage built and the screen wall. Should I post ya a few pics of the SMX screen in the box Dkaps came over the other day and we opened it up and had a look. I must say I cant wait to get it up and get this thing rolling I wanna watch some movies
post #69 of 1201
In regards to covering thr steel girder, what kind of adhesive did you use to hold the O.S.B.?
post #70 of 1201
builtwell5000
I used good old liquid nails. I let it cure for almost 7 days before I removed the clamps and still had one little spot pull away I dont think I used enough LN on that spot. I screwed it along the top and used the LN along the bottom edge of the beam and clamped it tight.
post #71 of 1201
Hello All
I have been trying to finish up the soffets this week and I am pretty close just a few more small sheets of sheetrock and GG and DONE
Here are a few pics of my flex duct before I sealed them up
Return
Supply
post #72 of 1201
Also I decided to go with sconces so that I didnt have to cut into the mass of my soffets
Here are the almost completed Soffets.
post #73 of 1201
Future Bass trap and can lighting that will go behind the SMX and shine down on my speakers
Here is a shot of my staggered stud wall where my door jam is. I think I am going to have it custom made since my jam is 8 1/2" wide
This is also a pretty good shot showing how I over lapped my sheetrock alternating the 48" & 54" sheetrock. Stretch rock is a Beautiful thing
going to order my Linacoustic this week and start getting some furring strips up. I'm also going to be using the fabricmate track system
post #74 of 1201
I'm about to build my stage. It would be cool if I could get some input on design. Please post links to your builds. I have a few pics saved of a few fellow AVS builders that I really liked but can always use more ideas
post #75 of 1201
I know sandman's stage is a frequently copied one.
Any turns in those HVAC runs?
post #76 of 1201
DC
The cold air return I did a 14' run of JM 1" duct board in the floor joist and boxed it in and then hooked in my return with the flex duct. I can yell into it and you can not hear me in the room above. The supply line I have not hooked up yet and just have it hanging in the furnace room. I will mess with it when I get the room done.
Sandmans stage is nice but I think I am going to copy Ronnie jacksons stage. I really like the way that turned out. He did a awsome job
http://www.avsforum.com/avs-vb/showt...ghlight=ib+sub
post #77 of 1201
Ronnies is great too. Good choice. No point in copying mine, it is just an equipment location behind a future false wall:
post #78 of 1201
Looking good W00lly
post #79 of 1201
Hello All
Well in between the rain and mowing my lawns I made some time to start working on the stage. I tryed to copy Ronnie jackson's stage build. I had to make mine a bit smaller Thanks to Ronnie for some pretty detailed photo's I think I came pretty close.
Here I used a bunch of scraps and did a mock up
Once I was pleased with the way every thing fit I started putting the puzzle together
I think I got alot done for the few hours I have into it. I hope to have it finished by the weekend. I'm not looking forward to dragging bags of sand into the basement
post #80 of 1201
I was wondering how much of a over hang for the lip should I do for the carpet . 1.5" or 2" ?
post #81 of 1201
Sorry to butt in but you HAVE to post a full size picture of your Avatar! It looks too funny!!
post #82 of 1201
HEHE I have no idea whos kid that is. I found it surfing for avatars one night. He looked pissed off that he was getting his picture taken. I thought it was funny too. I looked alot like him though when I was that little
post #83 of 1201
I finished up the framing today. Now sand not looking forward to that at all
post #84 of 1201
Oh man. Are those 2x12's? That is going to take a ton (literally) of sand! One word: Ibuprofen
post #85 of 1201
2x10's but ya I think its gunna take a ton I have a plan though. I bought a drywall cart to haul my sheetrock around when I started working on finishing the basement my plan is to wheel barrel it to the basement window then slide it down a ramp. Then load it on the drywall cart and roll it into the HT. Sounds simple but we will see
post #86 of 1201
Mr.Greenjeans
About time you showed up for a look
hey lookin' good...what is gonna be the first movie ?
post #87 of 1201
300 but by the time I get done there's going to be alot more movies that I will want to watch
post #88 of 1201
Not much has happened in the last week I run my own lawn biz and it has been raining like crazy and I am having a tuff time mowing 46 lawns in 3 days by myself. I hate wet grass and refuse to mow it wet but I guess green grass is better then burnt stubble but its cutting into my build time.
I am going to pick up sand and materials for the riser this weekend and get that going. Pics to follow soon
post #89 of 1201
[quote=W00lly;10999709]Well I got out the blue tape tonight and did a mock up of the actual size of my screen [snip]
I think I'm gunna have to lower this thing an inch or two. QUOTE]
Be careful with those directors and using any "rules" for where eye level should be on the screen -- You'll almost always be reclining, and that changes things a bit. You don't want to spend the whole movie with your chin on your chest. I think I'm at 1/6 screen and that's comfortable for me. I would not want the screen any lower, though.
post #90 of 1201
W00lly,
I finally got the chance to look through your thread and I must say you are looking good. Everything looks top notch so far and I am subscribing to your thread so I do not miss anything. You are ahead of me so I love watching what others do so I do not forget anything. Good job.
John
