The CopperFields Cinema - Page 32
post #931 of 1201
I remember that and he paid like 4k for one window. all the more reason to do this myself.
Sorry for responding so late, but yes it cost me 4k. Watching the guys that did this, it was back breaking work. It can be done solo, but I wouldn't recommend it. But if you were already planning on doing the digging on your own, then the cutting wouldn't be that much more work for you. Just remember to cut bottom, sides and finally top. Any other way and your blade will bind. The toll rental should be around $150 + whatever damage you do to the diamond blade.
post #932 of 1201
Michael
I'm going to do it myself. I'm not going to have to dig near as much dirt as your guys did and I bought a concrete chainsaw to do the cutting. I have watched alot of videos of the actual cutting and really think its going to be a piece of cake.
post #933 of 1201
WOW...that sounds like a LOT of work! Good luck.
Please post photos.
post #934 of 1201
I'll take a few pics of the outside of the house where the windows are going and you will see its not going to be that big of a deal to dig it out.
post #935 of 1201
...and really think its going to be a piece of cake.
Famous last words. I don't use that expression any more.
Good luck with that though.
post #936 of 1201
Hey WOOlly, nice build! Did you end up using fidelio velvet on your ceiling?
post #937 of 1201
Davey
I Didn't use the fidelio on the ceiling. I'm useing Danzian Black Celtic cloth as its going to be much cheaper and will match the lower wall fabric. I still have not finished it as I have moved on to some other projects that needed to be finished before winter.
This is as far as I got
post #938 of 1201
Thanks superMM
post #939 of 1201
Update
I got the holes dug for my egress windows last weekend I'm waiting on a another chain for the chain saw I wanted to make sure if I wore out the used one I had a backup it would really be bad to get it half way cut
Here is the front window only had to dig about 3 feet which was lucky as the gas line was about a foot deeper and would have had to have it moved. also ran into a few of my sprinkler lines they ran ran right through both holes
Rear window was a pain the dirt was so compacted I had to chip the dirt out the last foot
post #940 of 1201
Heres the beast thats going to make the cuts. I plan on doing the cuts and installing the windows this weekend.
post #941 of 1201
WOW...that looks like a lot of work. You didn't say you were digging more than one hole...
Can't wait to see the difference!
post #942 of 1201
For some reason..I was thinking it was on one window only too. Wow! That seems like a ton of work. Be safe with that monster saw.
post #943 of 1201
I have a friend that needed some extra cash that helped me out. I dug the holes while he wheeled the dirt to a large dump trailer that I rented. We probably have about 6 hours into the holes with all the BS'ing we were doing while working
post #944 of 1201
I spent the last 3 full days trying to wrap up the egress windows this week I have a little dirt work and some landscaping left to do and I'm finished. Drew was right it was alot of work and if I had to do it all over again I would have defiantly hired out the concrete sawing as I probably broke even on that part but all together I saved about 3K doing it myself. I have about $2600.00 into the windows, wells and materials and another $1200 into the saw and chains. I was quoted 5K if I dug the well holes and installed the wells and close to 7K if they did it all. I did get a little surprise when I started this project when I pulled down the 2" foiled foam insulation off the walls I found mold that had grown from warm air hitting the cold walls right where they were butted together. I plan on spray foaming these walls
post #945 of 1201
Mighty fine looking work there WOOlly! Congrats on getting past this part.
post #946 of 1201
Almost looks like I new what I was doing I don't know how happy I am with the stainless steel security screens as they are so thick they restrict alot of the light coming in but I don't have to worry about someone getting through them.
http://www.youtube.com/watch?v=n30Pf...eature=related
post #947 of 1201
Scott, good looking job. I know the photos don't show how much work was involved!
post #948 of 1201
Wooly,
Wow - turned out nice! I tip my hat to you.
I do not possess the nerves of steel it would take to open my basement walls with a monster saw.
A question: who is the Mfgr. of these windows, the security screen idea appeals to me?
post #949 of 1201
The windows I got are called escape egress windows and they have a option of adding the steel secruity screens. I ordered them through reddco.
http://www.escapewindows.net/
http://www.redi-exit.com/egress-windows.html#dhinswing
Tapco sells security screens that install over your windows
http://www.youtube.com/watch?v=KsE_jbQ7vKY
http://tapcoinc.net/index.php
post #950 of 1201
Scott - Looks excellent. I was expecting some action shots, though.
Did you put some sort of drain in the bottom of those window wells? I lived in a townhouse that had a basement flood due to a monster rain storm and the drain in the window well filled up faster than it could drain.
Hope the drainage is good!
post #951 of 1201
First time I ever saw mention of using a chain saw to cut through a concrete foundation wall. WOW. I'm curious if you looked into the economics of renting a diamond blade concrete saw.
post #952 of 1201
Man, we're a curious lot! If you didn't know the folks in the forum, we look like a bunch of know it all complainers!
"Did you think about drainage in that window well" & "Was it cheaper to rent a diamond blade vs. a chain saw".
BUT, we're just a curious bunch without malice.
post #953 of 1201
Second the drainage question, that was the first thing that sprang to my mind when I saw the pictures, since I spent all the time and money fighting the wet basement.
So how could you have stopped that mold from happening? Am I going to have that same thing happen when I put the foam insulation up on my basement walls next year?
post #954 of 1201
I did look into renting a saw but my walls are 8" thick and the biggest saws I could find to rent were 14" so I would have had to cut from both sides, Plus the chainsaw can make straight cuts right up to the corners.
Relax everyone
I should have taken more pictures of the whole process but was pretty busy thinking I should get the windows in there is over 12" of pea gravel in the bottom of the wells and three 4" drain tiles in a hole filled with gravel about the size of a 5 gal bucket that runs into the foundations strip drain thats hooked to the sump pit.
Chris
The mold issue was caused by not taping the joints, also when they glued it up it was at least 1/2 inch out from the wall so warm air could get behind it since I didn't have anything sealed the mold grew. after I get the framing up I plan on spray foam insulating the rim joists and the walls
post #955 of 1201
Scott,
Great job. looks real nice!
How was it cutting the hole for the window?
jimi
post #956 of 1201
Jim
The first hole went pretty smooth, I started with a new chain and it took me about 40 min to cut as I had to keep stopping and going inside to suck up the water that made its way inside. This last Sunday I had my pops over to help me do the other window I thought that since I just got a new chain that it would last cutting both windows, I was wrong about half way through the chain wore out, needless to say that sucked and made finishing the cut with the newest chain the next day a real pain the diamond pads that do the cutting were slightly bigger as the chain had not been worn yet and it kept getting bound I finally got it cut but it was not as pretty as the first cut.
post #957 of 1201
Jim
Crazy! LOL
So can U tell me more about the mold problem? what kind of materials were on the outside and inside of the wall? I'm just curious.
U mention the foam panels being away from the wall. isn't that the right way actually? so why did it happen?
thanks,
jim
post #958 of 1201
Wow Scott..!! That just looks like a butt load of work. I could'nt tell from your photos if you had a walk in entrance in your basement, but if not will you be able to fit sheets of drywall through your new windows in the future? looks like maybe...
post #959 of 1201
KNKKNK
not a walk out. I had my drywall delivered into the basement 2 years ago
post #960 of 1201
Jim
If you look at the 2 moldy pictures you can see that the rigid insulation was just glued to the walls with dabs of caulk here and there. I had not finished the walls yet so warm air was able to sneak behind the insulation from the crack between the panels and at the top. This would not have happened if they had been closed in, plus this wall is exposed to the outside air and gets vary cold.
