Originally Posted by
oldpainless68
So...same with this thread...no one has any helpful comments??
K
Hello..
As meationed before, you could use the NFS server from Tvix..
TViX NetShare v.1.08
http://www.tvix.co.kr/eng/support/EtcDriver.aspx
This server is soooo easy to use...
Just load it, and point it to the folder you want to share..
If you want to share multi folders, root directories, dvd-rom drives, you can also.. but,, with the following procedure..
In windows, make a directory where you will contain sub directories that will LINK to acutual root directories over different drives..
Example: Main directory = MOUNTS
sub directories in that = D (will be linked to D:\\ drive)
sub directories in that = E (will be linked to E:\\ drive)
Now, goto windows disk managment..
Highlight the Drive you want to share..
Right click on that drive, and choose option "change drive letter"
Once in this drive letter screen, choose ADD (do not chage actual drive letter).. By choosing ADD (folder), you then link this drive to a folder.. Since I have a folder called "c:\\mounts\\D" I will choose this for my D:\\ dvd rom drive..
Now windows see the dvd rom drive as d:\\ and c:\\mounts\\D
NOw..
With Tvix server, load it, and select the MOUNTS folder..
NOw..
Not sure what options you have for NFS, but on Tvix, I choose NFS (normal) mode..
On the client end (your media player), enter the IP address of your computer, and for the name use "tvixhd1"
For the name above, do not include the ""
You should not be accessing the Tvix server, and the Tvix server is looking at the Directory you showed it (which contains the sub directories that link to actuall drives)..
HOpe this works... On Tvix, works great, and have tired other programs like PRONFS, AllegroNFS, etc... but this was easiest and best..
