Originally Posted by oldpainless68
The video freeze and speedup that you refer to normally means the MKV was encoded via VFR. As the remuxer reads the timings to the files, when it nits them back together, it gives it a timestamp...so when playing back...you get video freeze with audio playing, or video speedup....as the Tvix tries to read the timestamp and keep the A/V in sync.....with these files, i just use MKV2VFR>AVI and that sorts the issue out.....Now I remember a while back, that Divco said they will support any file format/enocode that the LimHD can play......hence my comment about you Tvix owners needing to apply a little pressure on them and hold them to their word!...
just my 2 cents.
K
just my 2 cents.
K
Thanx again for the awesome info..
Do you know of any program that can tell me if the MKV is VFR? as this would be awesome, and save time, so I don't try to convert those files...
Do you think that TSREMUX will have problems with VFR files? or 1080 stuff..??
Thanx again..
....and it should be a BIG one!!!!
But that has nothing to do with the TViX, probably some faulty codec on my pc
