AVS › AVS Forum › A/V Control & Automation › Home Automation › Biometrics ~ Outdoor Fingerprint Reader
post #1 of 5
Looking to do something better than simple keycode garage opener for entry access.
I am thinking fingerprint, with 2 small kids I don't want a card or token for them to loose.
It would need to be all weather supported including rain and snow.
It would tie into a door strike, and would like to have it feed back into HAI system, to log events like person/entry time.
Sagem MorphoSoft
or
EKO
Any suggestions.
Just looking for something small, so the EKO is a plus there, but I want to be able to send off alters and such when the kids come in or whatever ...
TIA,
- Knaf
post #2 of 5
You should have a backup plan...
The ones indoors aren't perfect, the outdoor ones get dirty 10 times faster.
post #3 of 5
I was just going to use it with an electric door strike, so I _believe_ that I could still use a key as a backup plan. Correct ?
- Knaf
post #4 of 5
The indoor one I have lets you either use fingerprint, or a key , or a code on the keypad it has. I've never had to use either...but there is a backup..actually 2 on mine.
post #5 of 5
  Back to Forum: Home Automation
