AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › PJ's with Built-In Sleep Timer?
post #1 of 9
Maybe I'm getting old, but I keep falling asleep with the PJ going until 3:00 AM. You would think that the repeating movie trailer would jolt me from my sleep, or those annoying infomercials. No wonder I wake up dialing 800 numbers! I was wondering if anyone knows of a PJ with a programmable sleep timer. If not, I guess I will build my own timer and connect it to the 12V trigger out.
Don
post #2 of 9
You read my mind! lol Ive got a Mitsubishi HD100u and that is the only complaint I have, is that I cant leave it on while I fall asleep, any input would be awesome on this subject!
post #3 of 9
I might just make me a circuit that plugs into my 12V trigger out. My Panny requires two burst of "OFF" in order to shut down. Since I'm awake when I turn on the PJ (I think), then the remote handles the "ON" command. The 12V trigger comes active, whereby it will start the timer (microprocessor). I would probably set it for 3 hours. After the timeout period, it will send a double "OFF" blast to the IR receiver, telling it to shut down. Actually, I think I would space the IR commands by maybe 30 seconds, just in case I'm still watching a flick or something. This way, I can cancel the timer function.
Gee, you would think that the folks that designed the MX-3000 would have incorporated a RTC to handle this function.
Don
post #4 of 9
The BenQ w500 has a sleep timer.
post #5 of 9
Man, if you build that circuit you mind posting the schematics and code, that may be what I have to end up doing as well
post #6 of 9
How bout the Pansonic PT-AX100U?
post #7 of 9
Yes it has one, I use it.
post #8 of 9
Does it have like a sleep mode that it automatically goes into after a certain amount of idol time? Like so the brightness dims and doesnt waste bulb life?
post #9 of 9
Idol Time? As in after a DVD finishes? Most players have an option for that don't they?
It DOES have an option of background color(For Idle use), it defaults to Blue- but you can select Black as well.
See Page 34 of the owners manual:
http://service.us.panasonic.com/OPERMANPDF/PTAX100U.PDF
I used the Sleep timer last night aamof- set it for 90 minutes- I was sleeping in about an hr- and it was off this am.
hth
m
