Originally Posted by
Rao1
More I listen more I like these.
Nice!
Some suggestions.......
Pull your C607 forward just a few inches.......just far enough for the front baffles to be ahead of the TV Stand/equipment rack. Even if you only pull them forward enough for the front baffles to be only 1/4 of an inch ahead of the TV Stand/equipment rack.
It will make a difference. It will prevent any extremely immediate reflections off of the TV Stand/equipment rack. Your bass will also improve a bit.
Your soundstage is going to be rather tight, because of the small distance between the C607.
I would also move them each at least two or three inches from the TV Stand, to the left side and right side.
Putting a little more space between the C607's and the TV stand will be beneficial.
Try it and see how it sounds. Should open things up a little bit for you.
One other thing.
It looks to me like you have at least a foot .....to a foot and a half towards that big potted plant.
You may want to experiment with moving the whole TV stand towards the potted plant ......maybe 10 inches or so towards the potted plant. That will allow you to move your C607 a little further apart and get a bigger soundstage.
Listen, I'm just making suggestions to try help you make the best of your setup, with the amount of space you have to work with. I know you have a limited space to work with. But these little placement tweaks will make some improvements for you.
