AVS › AVS Forum › HDTV › HDTV Technical › DISH Net remote code for OLEVIA TV?
post #1 of 5
Does anyone have a DISH Net remote control code for operating OLEVIA HDTVs?
.......... Ed,
post #2 of 5
I would say you're probably going to be out of luck on that one. Probably will need something like a Harmony if you want a 1 remote solution.
post #3 of 5
I contacted Dish tech support last week on this same issue, the Olevia codes aren't current'y supported.
post #4 of 5
By the way, the code to punch into the Olevia remote to operate the Dish Net receiver is 3030.............. Ed
post #5 of 5
Anyone got the code the dish network remote on olevia tvs?? Would rather use the dish one than the olevia one....
also just in case...how did you put the code on the olevia remote??
  Back to Forum: HDTV Technical
