Originally Posted by
Kal Rubinson
No. If it is
fed PCM, the conversion from THD is being done in the player.
In my experience, all the HDMI inputs are identical.
Yes. Your issues are with the setup menus in the players.
Thanks for your help. I think my unit must be malfunctioning in some way. It recently had to be repaired due to inability to bring up the menu. Simultaneous to that, it had started to only read out MULTICHANNEL on HDMI input one, which was the only one in use. I had changed nothing about the blu-ray player settings, but it went from reading all the latest sound formats on the front panel display of the INTEGRA, to just MULTICHANNEL.
After I got it back from repair, I could bring the menu up -- same problem with the MULTICHANNEL readout however. Just for experimental troubleshooting, I hooked up the same blu-ray player (with no other changes performed) to the second HDMI input. That is when I first saw DTS MA AUDIO again. I was afraid to break the connection for fear it would not work anymore, so hooked up an identical blu-ray player (whose audio adjustments/settings were all identical), to the other HDMI inputs one by one.
Got MULTICHANNEL on all of them when it should have read out DTS MA AUDIO (or whatever the exact readout is for that). I'll continue to experiment for a bit, but if you know anything of HD DVD first generation (A-1 I think), the player is taking the DOLBY TRU HD and converting to PCM in a way that preserves the optimum delivery of the soundtrack, so that even reading MULTICHANNEL, you are getting the highest resolution? Thanks for your help!
