AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The Official INTEGRA DTC-9.8 Thread
The Official INTEGRA DTC-9.8 Thread - Page 2
post #31 of 12921
glad someone finally started a dedicated Integra 9.8 thread, info is spread out in too many places.
thanks E_H
post #32 of 12921
Does anybody know if this is upgradable (firmware flash)? I'm looking for something to replace my old sony ta-e9000es and this is something that i'm considering. I've called one of my local reps and he said that he could probably get his hands on one during the week of the 22nd for $1600 + 7% tax (New Jersey). Does anybody have anything else that they'd recommend looking into as well? I'm open to suggestions. I've looked at rotel but am not considering them anymore due to the fact that they're soooo sloooowwww in incorporating new products. I called their tech department and they said that only thing that is going to change in their new processor is the video end (hdmi) and remote. No new sound formats or anything. I've never even saw an onkyo or integra in person and if someone could comment on their build/sound quality i'd appreciate it. My sony is built like a tank with tons of things to reduce noise, but it's showing its age now. This integra doesn't seem to be as quiet though (0.05% distortion). I guess the old saying is true. They don't make them like to used to. My price range is around the price of this unit ($1600) but could go as high as $3,000 if needed for a noticable improvment. I'm thinking that anything newer than my sony will be a noticable improvment. Thank you for any help that you can offer.
My current setup:
Processor: Sony Ta-E9000es
Amp: Rotel RMB-1095
Sony Bluray BDP-S300
TV: KD-34XBR960
Lineconditioner: Monster HTS-5000 (Yeah I know monster suxs)
CD Player/Transport: Sony CDP-X3000 (Japanese)
Speakers (All Boston Acoustics):
Mains: VR3
Center: VR12
Surrounds: Micro 90x
Sub: PV1000
post #33 of 12921
One other thing... Where'd the chad remote go? Isn't this an upgrade from the DTC-9.4? I just assumed it had the chad until I looked in the manual.
post #34 of 12921
Originally Posted by oink View Post
I ordered the Emotiva MPS-1 amp the other day to go with the 9.8.
7 channel, 200wpc, 8 ohm powering my M&Ks.
Unfortunately, it is backordered and I may not get it for another month or so.
Ouch yeah another month, and not be able use your Integra, once you get it.
BTW what made you to go with the Emotiva? Just curious.
post #35 of 12921
Originally Posted by Gary Murrell View Post
I read the entire manual last night, this thing rocks based on the features, I don't think I will be able to resist
this thing has a full manual EQ setup for each speaker at a bunch of points , .5db level adjustments, .2 feet distances, Audyssey Auto EQ,
the list goes on and on...
-Gary
Dude, like does the list include the 47ms Audyssey processing time delay?
Here is a good example of why I take Internet advice at face value:
http://www.breitbart.com/article.php...show_article=1
Oh almost forgot, did you figure out why the "dual" HDMI output "rocks"?
post #36 of 12921
I did some research on the Audessey calibration system. Ifyou want it do properly you CANNOT use the included and less accurate microphone and built in firmware in the 9.8.
Rather you need an individually calibrated microphone, preamp and "professional" software (on the MultEQ Pro CD). However this system is only available to installers:
http://www.audioholics.com/news/trad...ci-av-receiver
http://www.audyssey.com/installer.html
So what will the typical consumer end up doing with this feature? Audyssey themselves frankly gives us the answer:
"This is why, after thirty plus years of trying this method most people don't like the results and turn it off."
http://www.audyssey.com/multEQ.html
This system qualifies as one of those "gadgets from hell" as you have no control over it. Change your seating position then you need to call the installer back out:
http://www.dailymail.co.uk/pages/liv...#StartComments
post #37 of 12921
like did you read the part about the rather complete manual EQ setup also being included and separate from Audyssey
-Gary
post #38 of 12921
The link to the manual now seems to be broken, anyone else having this problem?
post #39 of 12921
I don't care about processing time as long as audio and video are in sync when I watch the show/movie.
I like the idea of "dual" HDMI outputs. My SXRD allows separate calibration for each input. Ideally, I would calibrate each component and input combination; however, there are now obvious advantages for using the pre processor or receiver to "switch" and have access to the HDMI sound. But, if one (or two) components are "different" (but close) from others, I can give them their own output and calibrate that input on the TV accordingly.
post #40 of 12921
this thing has a full manual EQ setup for each speaker at a bunch of points , .5db level adjustments, .2 feet distances, Audyssey Auto EQ, volume settings separate for each input to account for differences between sources, mute db level set, sound modes applied for each separate input signal, 2 HDMI outputs, 3 12v triggers with adjustable delays, multiple IR in/out, balanced in/out, THX Ultra 2, dealer settings store/recall with lock/unlock, rack mount kit available, XM/Sirius, separate toroidal transformers for audio and video, sync delay per input, many crossover points per speaker, made in Japan
-Gary
Thinking about swapping my StageOne for the 9.8 - HDMI, new audio, EQ, main selling points for me.
post #41 of 12921
[quote=reincarnate]So what will the typical consumer end up doing with this feature? Audyssey themselves frankly gives us the answer:
QUOTE]
If I understand you correctly, you are implying that Audyssey is stating most people don't like Audyssey MultEQ and will turn it off. The reference you pointed to actually refers to graphic and parametric equalizers, not Audyssey. Audyssey is saying that graphic and parametric equalizers haven't worked well (for the last 30 years) since they only work in the frequency domain and their software is a step beyond.
post #42 of 12921
Given all the DTC 9.8 has to offer, at least on paper, does anyone know what might become of the Integra Research RDC 7.1? Will there be an Integra Research version of the DTC 9.8? An Integra Research unit positioned as a step up from the DTC 9.8?
Bruce
post #43 of 12921
Originally Posted by egcarter View Post
No online sales for Integra.
-E
As far as I can tell the Onkyo PR-SC885P sold in the pro line is essentially the same product. Any Onkyo pro retailer should be able to sell it on-line. It is due out next month.
http://www.onkyopro.com/model.cfm?m=...eamplifier&p=i
post #44 of 12921
The feature set for the 9.8 sounds suspiciously like what has been released so far (and mentioned by their rep at AVSforum) on the Sherwood Newcastle next gen receivers and pre/pros, including use of the Reon VP and Audissey EQ. I wonder if SN did the OEM on the Onkyo models with the option to use the basic design for their own branded products? Anyone know if that is the case?
post #45 of 12921
People who has no intention to buy this product, or are closet Onkyo haters should "cross their fingers" somewhere else! You know who you are!
post #46 of 12921
Yeah!!! Wait, Huh????
post #47 of 12921
yeah I noticed that and it is interesting but I think it stops at that
Integra is made in Japan, Sherwood is made by Etronics in Korea, I don't think they would have anything shared when it came to manufacturing these new pre-amps
-Gary
post #48 of 12921
Nope. Onkyo designs and manufactures their own products.
-E
post #49 of 12921
Costs more ($1800 vs $1600), gives less (unless you use it in a "pro" environment). The Onkyo Pro version is rack mounted by default. It has a 2 year warranty good in a "Pro" environment. Are you a DJ...run a House of Worship? This one's for you!
The Integra version has a 3 year warranty, but that's not valid in a "Pro" environment (read the fine print). The rack mount kit is < $100.
-E
post #50 of 12921
Bruce
The RDC-7.1 was discontinued and is SOLD OUT. But that's an Integra Research product, not Integra.
There will follow-on products...and Integra will be introducing a line of separates down the road, not just this one.
-E
post #51 of 12921
Hey Gary,
How are you planning on routing things with your VP-50 in the mix? It's just 1.1, so I'm wondering what will be the best way to rout all my sources, the VP and this Pre/pro. I love having my sources go to the VP first as I have different profiles, plus the lip sync, but that effectively kills the whole benefit of HMDI 1.3 audio processing.
post #52 of 12921
...snip..
Well, with both RS-232 and ethernet ports, I'd say it's a yes... there are three different sets of firmware in the units.
Integra products have been firmware upgradable for years.
-E
post #53 of 12921
CHAD is so tired. Custom installers have much better solutions, so they dropped that thing like a Hot Potato.
-E
post #54 of 12921
Eric, do you have a Pronto .CCF for the 9.8 yet?
post #55 of 12921
Humm....I wonder who that can be?
post #56 of 12921
Another question... As i've never heard or seen an integra product until a few days ago from this forum. What's the difference between integra research and integra? They both look the same.
post #57 of 12921
Can you explain what you mean by "gives less"? As far as I can tell, the specs and features are identical. The cost difference will disappear, or even favor the Pro model when they become available from internet sellers.
And the Pro version also has a three year warranty:
http://www.onkyopro.com/model.cfm?m=...s=Preamplifier
post #58 of 12921
Pre-ordered mine a week or two ago ... can't wait!!!
post #59 of 12921
This should be rather interesting, because there are a lot of pro sound dealers that discount rather heavily. And that could in fact help erase the price differential when they both end up at whatever their respective 'street prices' will be, and it could maybe even have it still end up costing less than the consumer version.
post #60 of 12921
Ohhh come on, you know... Was it one week, or was it two weeks ago???????
