I just got an 885 hooked up and ran into two 'problems'. The first would probably be the same on either the Integra or the Onkyo Pro so I thought I'd ask about it here.
I have an Oppo 980h into the pre/pro via HDMI and a Verizon FIOS (Motorola) set top box via HDMI set to output 1080i for HD and 480i for SD channels into the pre/pro. The TV is a Mitsu LCD 1080p. The pre/pro is set for 1080p upconvert (having it set to 'Through' doesn't help the problem much).
When switching channels on the set top box from SD to HD or vice versa there is an 8 second delay before picture comes on. If I change channels from SD to SD or HD to HD the picture comes on instantly, so it's only from HD to SD or SD to HD that causes the delay.
If I go directly to the TV with the set top box via HDMI I don't get the delay so I know the pre/pro is causing it. I'm just curious if this is typical or can it be remedied?
The second problem is when I hook my Axiom ep500 sub up using an XLR cable from the pre/pro the signal is sooooo hot I have to keep the sub volume all the way down. As soon as I turn it a hair above all the way down it is rediculously loud (This is from the Onkyo Pro's internal calibration tones). I switched to an RCA cable and it was a lot better but still pretty hot (If 1-10 is quiet to loud I'm still at maybe 2 and am 12db above my speakers). Any thoughts??
