AVS › AVS Forum › Audio › Speakers › Martin Logan Owners Thread
Martin Logan Owners Thread - Page 25
post #721 of 731
Hello everybody!
I am at it again. I am looking at buying some Martin Logan Source's. However, I have some concerns with powering them. ML has a power rating of 20-400 Watts at 5 ohms. Thats allot of watts!
I have everything running of my Marantz SR5008 Reciver providing the power for two Motion 12's and a motion 8. Can it handle adding these things? Marantz have it rated at 140 Watts at 6 ohms.
These sources seem to be a really good deal. "I just wish he had the boxes." : /
post #722 of 731
It depends on how big your room is. My room is 13ft W x 20ft L x 8ft H and I ran my ML ElectroMotion ESL (6ohm), ML Source (5ohm), and Encore TF (4ohm) off an ancient Marantz SR7200 (110 watts @ 8ohm) for 2 years just fine before I bought a separate 5 channel amp. If you have a large room the receiver might struggle a little bit or get warm. You should be fine generally speaking unless you really like to crank it.
post #723 of 731
The room it will be in is fairly small. Its Total Vol is 1,400 Sq.ft. I am just wondering if my receiver will be enough to enjoy them. With out risking the receiver in anyway.
I would prefer some Purity's because they are powered. But I doubt I am going to be able to find any for anything close to the price I could get these. I am hoping to pick up the sources for $500. They don't have boxes or anything but they look like they are in pristine shape.
post #724 of 731
Hi guys, Best Buy has the Martin Logan motion 40's open box for $1163.00.
Is that a good deal?
Femi
post #725 of 731
Sounds like a good deal to me provided they're in good shape. I bet you would have a hard time finding a good set used for less.
post #726 of 731
they are in good shape but they are missing the grill cover
post #727 of 731
I think you'll be fine. My room is about the same size and I run my montis off of a denon avr-x4000. Never runs out of pore and is not too warm at all.
post #728 of 731
Hey everyone. I'm new to the Martin Logan speakers. I am looking to upgrade my system. I'm thinking of going with the ESL's and the Motif X. Is that too much center speaker for those fronts? I won't get a chance to listen to the pair before I buy. Wondering if anyone has that setup or if I should go with the Electromotion C2 center? Any advice would be great!! Thanks!!
post #729 of 731
What do mean by too much? It won't be too loud and overpower them if that's what you mean.
post #730 of 731
If the extra cost isn't an issue for you, absolutely go with the Motif. It's a fantastic center channel.
That being said, the Electromotion C2 is great as well and you'd probably be happy with either one. But the Motif is just that much better.
post #731 of 731
I have the EM ESL's and a Motif (not the X version though) and it blends right in with the EM ESL's just fine. I've not heard a C2 to compare though.
  Back to Forum: Speakers
