AVS › AVS Forum › Display Devices › Display Calibration › pioneer pdp-5070hd initial settings
post #1 of 3
Looking for initial break in settings for the pioneer pdp-5070hd plasma?
post #2 of 3
Greetings
Use a test disc ... or even something simple like the THX optimode on any THX DVD. It will be better than blindly using other people's numbers. It will also take you all of 5 minutes to do.
Regards
post #3 of 3
I couldn't agree more with Michael TLV, but if you must use someone else's settings, there is a whole thread devoted to ones applicable to the 5070.
This is some of the pertinent info.
While these provide a starting point, everyone's room and attached equipment is different. You still should use a test disc.
