AVS › AVS Forum › Audio › Speakers › SURROUND SPEAKERS - Bipole, Dipole, Quadpole, Omnipole... WHICH ONE?
SURROUND SPEAKERS - Bipole, Dipole, Quadpole, Omnipole... WHICH ONE? - Page 6
Poll Results: There are many surround speakers out there now, but the ones below would have to get my highest recommendation for the most remarkable & effective design Which of these have you had a positive experience with?
This is a multiple choice poll
  • 32% (13)
    Mirage OMD5 (or any other Mirage Omnipole)
  • 7% (3)
    JBL P520WS / Infinity ES-250 / Infinity Classia C255ES (Dual-monopole for 4 channels from 2 speakers, but also Bipole & Dipole switchable)
  • 17% (7)
    Axiom QS8 or QS4 (Unique Quadpole design)
  • 15% (6)
    Paradigm ADP (Many models available with this design, where the tweeters run Dipole, but the woofers are Bipole)
  • 7% (3)
    Monitor Audio BXFX or RXFX (Single woofer, but the tweeters can switch to either Dipole or Bipole)
  • 15% (6)
    Monitor Audio GXFX (6 drivers, including a ribbon. (Monopole / Dipole switchable)
  • 5% (2)
    KEF 26/2DS (Dipole only, alas... but with two 6.5 inch side woofers and a front-firing 8 inch!!! )
40 Total Votes
post #151 of 543
well here is my dilema.... i'm putting together a 9.2 system utulizing 11 speakers using both the new height and wide speakers. across the front sound stage there are 5 monopole identical speakers LR are 30 degrees off center and the Wides are another 30 degrees for a total 60 degrees off center. Also there will be timbre matched but smaller monopoles as height speakers at 45 degree off center and close to the ceiling. what i have left is a pair of monopoles( same as the heights ) and a pair of bi-poles.
My question is that since the Wides basically blend the fronts with sides as they sit between side and front ( the Wides are actually on the side walls to obtain the 60 degrees ), now opinions PLEASE, start with bi-poles as side surrounds and monopoles for back surrounds or monopoles for side surrounds and bi-poles for back. I'm thinking that the addition of the Wides will change the dynamics of the typical side surround ( I plan on the sides being mounted at 110 degrees and approx. 2 feet above the listeers ears )...
So guys what do you think?????
post #152 of 543
bump
post #153 of 543
Originally Posted by deepstang View Post
I watched U-571 on blu ray and was amazed at how hard that 10 year old movie works the surrounds!! There was definitely some low content being sent to the surrounds, because I have never heard my surrounds strain like that. Keep in mind that I have 8yr old in-walls that came with the house mounted on the rear wall 4 feet directly above (and right behind) the listener.
I have decided that since I can't place speakers on the side wall, I will get bipoles like:
Can someone recommend a speaker designed like this that can
(1) get to 80hz and yield a large/wide soundstage
(2) I don't want to spend more than $350 to $400
(3) Is a relatively effecient 8 ohm speaker/bipole
I don't want to get the Klipsch because they will be a bit too brite and too much of a mis-match for my AV123 mains.
I can't believe that I have not seen this link before of Bipole/Dipole speakers:
http://www.electronichouse.com/slide...egory/4476/727
I am still open to suggestions, but that link is a GREAT resource for bipole/dipole options.
post #154 of 543
I had an opportunity to listen to a pair of Infinity ES250 speakers.....which has been recommend here several times. IMO, they sounded pretty thin. Although it may be an unfair comparison, they had a pair of affordable Polk TSI-200 bookshelves with dual 5" drivers...and they blew the ES250 out of the water. I know it is unfair to A/B them, but the 5" driver from the ES250 really, IMO, could not perform. I tried the ES250 in bipole and monopole mode in the comprison. I am not sure if I believe that the ES250 can handle frequencies lower than 120 Hz, thus making explosions sound believable. I know the sub can handle lower frequencies; however, as I posted earlier I would prefer the surrounds to handle at least 100 Hz competently.
post #155 of 543
I just bought Axiom QS8s but only have one of them installed currently (I'm new to drilling holes in walls!!!). I think it matches my Monitor Audio GS10s and LCR very well. The only annoying thing is that when watching TV some shows have the surrounds so low that to even hear them I have to boost the surround by 12db (my one surround is calibrated to the correct 75db)!! I swear the sound mixers of these shows have no clue about properly calibrated systems and probably just calibrate volume levels by ear.
post #156 of 543
Originally Posted by mike2060 View Post
...The only annoying thing is that when watching TV some shows have the surrounds so low that to even hear them I have to boost the surround by 12db (my one surround is calibrated to the correct 75db)!! I swear the sound mixers of these shows have no clue about properly calibrated systems and probably just calibrate volume levels by ear.
Not really. TV show engineers are usually in mixing environments closer to your living room than film sound mixers, and most will know what they're doing.
Laziness and sameness tend to prevail, though.
Many shows are still monitored and mixed in straight stereo.
Sometimes, it'll be stereo with Dolby Surround (4.0) encoding.
Either way, ProLogic IIx processing will usually do the best job matrixing them to 5.1 or 7.1
(Not all sound engineers would like you doing this, of course.)
More and more TV drama is being done in 5.1, and reading reviews of such shows on say, Blu-ray.com, you tend to find that most are very competently put together, but still a bit light on the surrounds.
In Australia, Free-to-air Digital TV is broadcast with Dolby Digital, and this can accommodate 5.1 channels. Most of the time though, it'll be 2.0 - even for shows mixed in 5.1, which is a damn shame.
post #157 of 543
Nicely spotted. Great to have so many contenders on one page.
post #158 of 543
Interesting that you didn't choose Monitor Audio surrounds!
How do you find the QS8's perform with respect to the spread of sound, height, width soundstaging, etc - compared to dipoles or bipoles.
Those vertically opposed woofers really make me curious...
post #159 of 543
Gee, that's weird. Sure haven't found mine thin-sounding.
I've found the Infinities very neutral and well-balanced, and roll mine off at 100Hz to keep it clean in my room.
Did you hear them in dipole, bipole or dual-mono mode?
Dipole will always sound thinner of course, because the woofers are running out of phase.
(Not crazy about this, which is why I'm partial to dipole designs like the Monitor Audios or Paradigms.)
Speaker placement, brick or plaster walls, your seating position and the amp's calibration would also have a huge effect.
Not sure if the Polks tend to exaggerate the low end, although I doubt it.
I've always found that generating loads of bass from wall-mounted speakers isn't exacting the last word in sonic accuracy. Similar keeping speakers away from the room boundaries to avoid boominess.
post #160 of 543
Thanks for the feedback E. Yeah, the ES250s were on a carpeted shelf not against a wall Also, neither speaker were in the dipole setting. It just seemed that a lot of sound was not coming out of the speakers. I learned a while ago that you can't turn lead into gold. I am definitely not calling the ES250 Betas "lead", but it is hard to get a lot of sound from such a small enclosure and small 5" drivers. Still on the fence between the ES250s and the Energy RC-R. BTW, the tweeter on the ES250 was very natural and not nearly as bright as the Polks.
post #161 of 543
Not sure what Polks they were, but I'd steer clear of their 2-tweeter 1-woofer designs.
As I say, I was actually getting a little too much bass from my ES250's, but it's very room and wall dependent. Tonally, they're very accurate & neutral, and a near-perfect match for my VAF DC-X fronts.
Haven't heard the Energy's yet, but I'll be recommending them to a friend in a couple of months and should be able to try them out then.
As a guess though, I'd have a lot more faith in the accuracy of the Infinity.
Don't forget the ES250 has been superceded by the Classia, but JBL make the P52OWS.
post #162 of 543
I just installed the second one last night so I haven't had a good chance to listen yet. I really don't have a lot of experience with surround sound so I can't compare them to others. I didn't choose the MAs because they are $2k or I'd have to find them on Audiogon. Also I wasn't sure if they were as good as the Axiom QS8s in regards to the soundfield they create. But I am really curious as to how the MAs would sound in my room and I'm sort of having second thoughts as I really like the sound of my GS10s so I'm wondering how their equivalent surrounds sound.
post #163 of 543
I finally got a set of used Infinty Beta ES250s....just like Electric_Haggis has been recommending.
I must say it is nice to have the option to play between the different settings: MONOPOLE, DIPOLE, BIPOLE. I have decided to stay with BIPOLE because it is mounted on my rear wall. FYI, this is a 5.1 set-up.
To be honest, I am not that impressed with this upgrade. I was expecting a bigger improvement over my poorly positioned (per DOLBY and THX positioning diagrams) 12 year-old home-builder installed JBL in-walls. I think those old in-walls sounded pretty OK b/c they had 6.5" drivers compared to the dual 5" drivers with the ES250. I must admit, those Infinity CMMD tweets are smooth. I just don't have as much impact from the surrounds, and i am not sure if I feel like I am getting a larger surround effect. I guess I am hard to impress. I am sure they will warm up to me with a little more time. Read my question below the pics as maybe I may not have them dialed in properly with Audyssey.
OLD SURROUND pics:
NEW surrounds (ES250) w/ the in-walls disconnected:
QUESTION:
I ran Audyssey with the speakers in MONOPOLE mode, and than switched it to BIPOLE mode afterwards. Does anyone have a recommendation as the best way to calibrate BIPOLES with using Audyssey? FYI, I have an Onkyo 605.
post #164 of 543
QUESTION:
I would re-run Audyssey with them in "bipole" mode. This setting vs. the monopole setting could impact their in-room LF response and impact the crossover chosen by Audyssey. Also, the overall level measured by Audyssey could be different, which would affect their "trim" settings.
Craig
post #165 of 543
I have been researching the best route to go with my surround and rear speakers and this thread has been a huge help. I am currently finishing the basement in my home and it will be a dedicated man cave with a theater setup. I currently have a Denon 2310, Klipsch RF-5 fronts and RC-62 center. I am unsure of the best route to mount my surrounds and rears and what speakers to use. The room is 36' long and 17' wide. The couch will be 13' from the TV. I plan to mount some RS-52's or QS-8's for sides but don't know what to do for rears. Mount them on walls just further back? I feel that would be pretty far away then is the issue. I don't have the luxury of a back wall because there will be a pool table behind the sofa. The walls currently without sheetrock so wiring or going in-wall or in-ceiling is still a possibility at this time and I want to make a decision so i can wire it accordingly. Thanks for the help.
Ryan
post #166 of 543
Ryan
Wow, that is a pretty long room. I may not be the best to give advice, but you may be able to get away from mounting BOTH the side and "rear" surrounds on the side walls. I am sure you have seen the diagrams for surround positioning from both the Dolby and THX websites (can easily be googled). You can position your side surrounds slightly in front of the seating position and the rear surrounds behind the seating position. I have even also seen people place the rear surround speakers on the floor (or short table) behind the sofa/listening area and have them pointed up. In the same regards, you can have some in-wall ceiling speakers positioned behind the seating area and function as the "rear" surrounds.
post #167 of 543
Ryan
A good 5.1 setup may be the best way for you. The only other good option would be in-ceiling (ugh!) speakers. I'm no fan of in-ceiling speakers as you might guess. The Emotiva ERD-1s are on sale now through Dec. Even though they are 4 ohms there are quite a few people driving them with an AVR with no problems. I've done this myself as I'm an owner of a pair - for almost a year now. They sound great - surprising for such a small package.
post #168 of 543
I am putting together an 11.1 system with the following components and I could use some assistance. I have zero real world experience with anything other than a stereo setup so I'm stepping into this big time. What I'd like to prevent is stepping into it'.
Here is my purchase list so far:
AVR - Denon AVR-4810CI - 11.1 (internal amps will be used for surrounds and other zones.
Outboard amp to drive the fronts and Wides - Wyred or Emotiva
LCR Speakers - JTR Quint8
Wides - JTR Slant 8
Sub - Danley DTS10
All that remains to make this complete are the surrounds. Please see the attached drawing for placement in the room.
I've read the various discussions arguing dipole / bipole / mopole / multipole, etc. Regardless of the theoretical merits on monopole, most seem to conclude that di / bipole is preferred by most people. But, the biggest qualifier is the room. As you can see from my room drawing, I have a pretty good distance between all the speakers and the nearest listening position is just under 7 ft for the surrounds (the left seat on the couch will measure about 6.5 ft to the right surround. The room is live'.
With the exception of the wides, all the surrounds and height speakers will be flush mounted into the mansard which faces down at 45 degrees and the speaker centers will be at approximately a 9' elevation.
I do want all position on the couch and to some extent the recliner to be in the sweat spot. I certainly wouldn't be happy if it was just the lonely man' seat in the middle. Well, I might be but no one else would be. ;-) I'm not too concerned about the table behind the coach.
So, with this setup I think I could go all monopoles but I'm ready to be convinced otherwise.
Let me know what you think and thanks for all your help. I'm very close to completing this setup and looking forward to getting it put together in the weeks to come.
Louis
post #169 of 543
Originally Posted by Mathelo View Post
So, with this setup I think I could go all monopoles but I’m ready to be convinced otherwise.
I would stick to monopole surrounds. With 4 speakers firing simultaneously, you'll get good envelopment (without resorting to diffuse speakers) and still maintain clear directionality. The only suggestions I'd make to your proposed set-up would be to move the side speakers forward so that they're in line with the seating (no sense having both pairs of surrounds rearward of the listeners), and use 5 of the same speakers up front (either Triple 8 or Slant 8) for a consistent soundstage.
post #170 of 543
Sanjay,
When you say the side speakers I assume you are referring to the wides. And yes, I would line them up with the fronts so that they are all on the same plane and at the same height.
Louis
post #171 of 543
No, I meant the surrounds at your sides (as opposed to the surrounds behind you). Keeping the side speakers directly to your sides (+/- 90 degrees) will help stabilize lateral imaging and give you better rear-vs-side separation in the surround field. The latter effect is lessened when both pairs of surrounds are behind you.
If you're going to have all 5 front speakers lined up on the same plane, all 5 at the same height, all 5 powered by the same amp, then I really would encourage you to consider using the same model at all 5 positions.
post #172 of 543
Sanjay,
Louis
he was referencing the side surrounds not the wides
post #173 of 543
No, I meant the surrounds at your sides (as opposed to the surrounds behind you). Keeping the side speakers directly to your sides (+/- 90 degrees) will help stabilize lateral imaging and give you better rear-vs-side separation in the surround field. The latter effect is lessened when both pairs of surrounds are behind you. If you're going to have all 5 front speakers lined up on the same plane, all 5 at the same height, all 5 powered by the same amp, then I really would encourage you to consider using the same model at all 5 positions.
Its not practical for me to include the same model for the Wides, price and size considerations overrule here. But the Slant8 is tonally identical to the Quint 8. Same mid/hi driver and extends down to 80 Hz. Seems like that should be okay.
I've also read in this forum that the wides, while receiving substantially more signal than the surrounds, still is considerably down from th LCR. Is this not correct?
Finally, regarding the position of the side surrounds, I can certainly experiment with this placement but this is according to the Audyssey DSX Configuration. Do you not agree with this?
Louis
post #174 of 543
Unfortunate, since you're making a concious effort to keep everything else identical for the front soundstage.
Would you be comfortable swapping one of the Quint 8s (say the left front speaker) for a Slant 8 in your set-up? You don't have to answer; it's just a mental litmus test for yourself to see how "tonally identical" you really feel they are. Just something to consider.
I don't, for the reasons I mentioned previously.
post #175 of 543
Unfortunate, since you're making a concious effort to keep everything else identical for the front soundstage. Would you be comfortable swapping one of the Quint 8s (say the left front speaker) for a Slant 8 in your set-up? You don't have to answer; it's just a mental litmus test for yourself to see how "tonally identical" you really feel they are. Just something to consider. I don't, for the reasons I mentioned previously.
Sdurani,
Are you familiar with the Quint 8 and Slant 8? The Quint 8 has four 8" drivers for bass / midbass and a fifth 8" coaxial driver for mid/hi. The Slant 8 is a single 8" coaxial driver. The same coax as in the Quint 8 but absent the 4 bass drivers. The Slant 8 would be a poor substitute for the Quint 8.
There is another alternative. JTR makes another speaker, the T8, which is the same as the Quint 8 sans 2 bass drivers. If balance across all 5 is that important, I might be able to go with 5 T8s instead of the prior configuration.
The key question for me is just how much signal do the Wides actually take on. I thought it was considerable down from the LCRs.
Louis
post #176 of 543
Yes.
Then how will it sound when something moves towards the left of the front soundstage and transitions from the Quint 8 to the Slant 8?
Which is what I suggested 7 posts up. The Quint 8 may go lower than the Triple 8, but that difference in bass can be covered with your subwoofer. Anyway, it was just a suggestion. Nothing more.
post #177 of 543
Yes. Then how will it sound when something moves towards the left of the front soundstage and transitions from the Quint 8 to the Slant 8? Which is what I suggested 7 posts up. The Quint 8 may go lower than the Triple 8, but that difference in bass can be covered with your subwoofer. Anyway, it was just a suggestion. Nothing more.
Suggestion definitely appreciated. I was underestimating the role of the Wides. I'll give this more thought.
post #178 of 543
Sanjay,
Related question. How important do you think the tonal balance is with the surrounds relative to the front speakers? Most things I've read put a low priority here.
JTR doesn't make a surround speaker that meets my requirements exactly although I think I can get JTR to provide a custom box but there are many other solutions that will give me a flush mount for probably less money.
Thanks again for your opinions.
Louis
post #179 of 543
Not as important. Even in this day and age of surround sound, the front soundstage remains critical. That's where your attention should be focused, whether watching movies or listening to music.
By comparison, the surrounds are less important. Save for the occasional direction effect, they're still used primarily for ambience. As such, tonal match between the front speakers and the surrounds is not as critical as between the various front speakers.
Of course if you can use the same speaker model at all locations, nothing like it. But that's impractical for most people. It's too bad JTR doesn't make an in-wall version of the Slant 8, using just their coaxial driver (frequencies below 100Hz from the surround channels can be rerouted to the subwoofer).
Happy Thanksgiving Louis.
post #180 of 543
But building a surround from something like the B&C 8CXT 8" Coaxial Driver
http://www.parts-express.com/pe/psho...53&ctab=2#Tabs
should get pretty close. Just needs a crossover and a cab to complete the picture.
And Happy Thanksgiving to you as well.
Louis
  Back to Forum: Speakers
