Originally Posted by sdurani
Not as important. Even in this day and age of surround sound, the front soundstage remains critical. That's where your attention should be focused, whether watching movies or listening to music.
By comparison, the surrounds are less important. Save for the occasional direction effect, they're still used primarily for ambience. As such, tonal match between the front speakers and the surrounds is not as critical as between the various front speakers.
Of course if you can use the same speaker model at all locations, nothing like it. But that's impractical for most people. It's too bad JTR doesn't make an in-wall version of the Slant 8, using just their coaxial driver (frequencies below 100Hz from the surround channels can be rerouted to the subwoofer).
Happy Thanksgiving Louis.
Do you consider the Height speakers more as surrounds or as part of the front stage? I recognize they are placed in the front stage but I've been under the impression they are used more like surrounds, i.e., adding
ambiance.
Louis
