Pale, thanks again... I think that seals the deal. You are more or less running the exact same setup I'll have. Not much difference between the 1120 and 21 either, except maybe discrete amplification. I just recently bi-amped my M70's and they sound great (but passive sadly, wish the Pio had active x-over settings to make this feature infinitely more valuable) .
One last thing to your point, I simply am not able to mount 1-3 feet above the listener, even if WAF didn't prescribe it, there's just no way to do it in the listening room. Is it going to be drastically worse if it's 5-6ft above ear level? I would imagine the bi/di-pole setup by design would largely offset any performance degradation as compared to a mono surround.
