Originally Posted by zheka
After reading this thread I just placed order for a pair of omd5s for my side surrounds.
They will be used in a (smallish) dedicated HT/music listening room, roughly 12x22x7.5
I can be fairly flexible about the placement.
How high should I place them?
I currently run a pair of ascend 170se (direct radiators) for side surround. They are positioned slightly behind of MLP and vertically aligned with the front stage speakers with tweeters approx at ear level.
Should I place the OMD-5s higher? Or vertical placement is not as important for omnipolars?
Any feedback is much appreciated.
They're pretty flexible, but each room is a different beast.
I'd suggest starting at ear level, then try moving them up in increments of a foot or so until you're happy with the soundstaging, diffusion and blending with the fronts.
Having them pointed down and perhaps angled inward or toward the front or back may also work nicely.
Let us know how you go! Anyone else care to chime in?
