Originally Posted by Skylinestar
Anyone place their side surround speakers at 60-80 degree? How does it sound?
ITU spec states that surrounds for 7 channel setup can be placed between 60-150 degrees. With the side surrounds at 60-80 degree, it'll be closer to the arrangement of Audyssey DSX Front Wide. Problem is I'm not sure if Klipsch WDST design can work out for that placement. What say you?
First I've seen of that.
Personally, I wouldn't even bother trying anything less than 90 degrees.
Surrounds aren't mixed to come from the front!
Having my dipole/bipole switchables at around 90 degrees and 2 rears at around 150 works beautifully.
Front speaker width has a big effect on front/back blending, though.
My front left/right are around 3 metres apart, and listening distance is about 3 metres back.
Side-Surrounds are about 4 metres apart, and rears are about 2 metres apart, and 2 metres back from listening position.
These relative distances are the best I've yet heard
