AVS › AVS Forum › Home Entertainment & Theater Builder › Outdoor Theaters › What color should I paint my screen?
post #1 of 4
I picked up an InFocus LP425z for movies by my campfire and I have a 9' x 12' paint drop cloth that I'm using for a screen. It is a tan color and I thought I could paint it easy enough and maybe get a little better performance from it. I'm not to concerned about getting high quality, but if I can throw some white, silver, gray or whatever color paint on it to make it better, I thought I would.
So what color is best for an outdoor, drop cloth screen?
post #2 of 4
White is the best color for an outdoor movie screen, but only if you bought it that way. I think you will run onto problems with paint peeling, chipping, creasing, etc.
Personally, I don't believe people go to outdoor movies for the Picture Quality OR the Sound Quality. They go to have a good time.
I think the only person that will be bothered by this you. Once it's dark out, I don't think the color of the screen makes much difference.
Tom
post #3 of 4
Honestly it doesn't bother me either, I was hoping to gain a better picture and possibly be able to start a bit before it get completely dark (so the kids can watch their movies before its too late).
post #4 of 4
In that case, I don't think painting the screen ANY color will let you start the movie early enough to make a difference.
Tom
  Back to Forum: Outdoor Theaters
