AVS › AVS Forum › Display Devices › Ultra Hi-End HT Gear ($20,000+) › Burn-in: Real Or Imagined???
Burn-in: Real Or Imagined??? - Page 22
post #631 of 665
You know you guys are killing science with EGO. No wonder we have intelligent design. Earl, good for you for not coming back! Whatever happened to attacking the argument not the person? Or is it me? I see it as please accept my argument or you are an idiot-whatever. I think I may convert to a subjectivist view.
post #632 of 665
Sorry, how would that make any sort of sense?
I've been to a few conferences in my own field (biology) where the arguments got heated. It didn't for a moment lead me to consider becoming a creationist. Nor did science seem to be in any mortal danger.
I'm also wondering how anyone can be sure anyone has 'left' here, besides a private communication to that effect.....
post #633 of 665
Not to speak for Randy, but I don't think he was being literal about converting to subjectivism. Just expressing frustration, which I share.
Sanjay
post #634 of 665
Originally Posted by AndreYew View Post
Todd, I don't understand: what's the difference between a mode and a resonance? In my usage, both are the same, and are produced by self-reinforcing reflections or inputs. Or, mathematically speaking, both are eigenfunctions of the wave equation with boundary conditions.
--Andre
Indeed, and you can add false "boundaries" with radiators with delayed, filtered, processed, etc, signal applied. Needless to say they aren't real, physical boundaries belonging to the room.
post #635 of 665
Randy and all
The system here messed up and I was not notified of any postings to this thread for nearly two weeks. I did not stay away for any other reason than I did not know that a discussion was going on. I thought it dies as so many of these arguments do.
Hence I am not at all up to speed on the discussion, too much has passed. But I did notice that JJ had some comments to me about "smoothness' in a LF fitting algorithm.
Smoothness of the response in any room in the statitistical region is always a fixed quantity - as Schreoder proves "66% of the time it is between +6 dB and -11 dB ..." so of course absolute smoothness in any large venue is not going to happen. But in a small room, in the modal range, the "smoothness" is much worse than what it is in the statistical region - fewer modes greater variance. The LF algorithm for setting up the subs will seek to make the small room much more like the large room or much more like the "smoothness" found in the statistical region, but it is doubtful that it could ever be "smoother" than the large room (although with multiple subs this is not a given and it could be the case, but I seriuosly doubt it). So setting the subs to yield the "smoothest" spatial and spectral response is most likely going to yield the same statistics as a large room, which is not actually all that smooth at all. Its all relative.
post #636 of 665
--Andre
Andre - not to speak for Todd, but a mode and a resonance are not the same in physics jargon. One is the spectral location of the Eigenfrequency and the other is the spatial shape of the Eigenmode. They relate to the same modal solution set, but are different manifestations. In math we would say that the mode is the solution set or function associated with a specific characteristic value of the solution.
post #637 of 665
Sanjay
Correct.
post #638 of 665
I wasn't sure and I was wrong.
post #639 of 665
Sanjay
I didn't think it was literal; I just don't get how one would go, even figuratively, from 'I'm frustrated with the tenor of the debate between experts' to 'it almost makes me want to embrace pseudoscience'.
Earl: if you aren't getting new post notices, perhaps check that your email software isn't auto-tagging AVSForum notices as 'junk mail'. I've seen that happen.
post #640 of 665
Let's go back to regular debate on stereo bass. I just was disappointed in the tone of the debate and the personal attacks. If that doesn't upset you, then that's fine-it does me because I thnk an outside observer might see it as less than professional. That was my point. I would expect it at a Texas school board meeting!
However, just to clarify, what I said about becoming a subjectivist was hyperbole.
post #641 of 665
The thing is that I have gotten ALL of them since yesterday, but nothing before that until Jan 18th. So its not any filters on my end unless they change, but I'm not changing them.
post #642 of 665
Given the title of this thread, it seems unlikely anyone looking for a professional take on stereo bass or room modes would stumble into it. Anyone thought of starting a new thread with a relevant title?
post #643 of 665
I agree with this. FWIW, in my dictionary:
Mode: physics: "Any of numerous patterns of wave motion"
Resonance: physics:"The increase in amplitude of oscilation of an electric or mechanical sytem due to a periodic force whose frequency is equal or very close to the natural undamped frequency of the system".
A related question is whether you can add or remove modes from a room. if you define the mode as strictly the individual standing waves series for each set of walls, then you can't. If the modes are considered as the combined standing wave pattern for all axial, tangential and oblique paths, then i think you can remove them at least. As an example, if you add sources at randomized locations throughout the space you can make the the response arbitrarily flat (spatially). I modelled this in a previous paper using 5000 subs in a small room - quite flat I assure you!
I'm not so sure you can make the room have MORE modes (consider one sub in the corner, exciting all modes equally as a reference, then add more subs)...?
post #644 of 665
I'm out of this thread. It's not worth the effort to argue about other people's straw-man proposals.
Earl, I pretty much (but not quite in the edges) agree with your last statement in most ways. It would require a blackboard to explain and I think most people here would want to stuff the e^jwt's up our noses if we did it here.
post #645 of 665
Good idea, how about "Stereo Bass: real or imagined"?
post #646 of 665
Oh well, at least after 22 pages we can agree that cable burn-in is true. No ?
Oops.
post #647 of 665
I still don't get notified of posts in this thread.
Todd, I agree that I don't see how any electronic means can "add modes". If there were a lot of them, like the walls were covered, then one could simulate a mode and it would begin to approach a true mode, but a limited number of sources could only roughly approximate such a thing.
Also, I don't think that you can "remove" a mode from a room. You can setup situations that won't excite it, but its still there. And in fact, no matter what you do it will get excited in a transient way, albeit talking transients and LF modes is kind of silly.
post #648 of 665
I have also pondered the difference between "removing" and cancelling or not exciting a mode.
post #649 of 665
That would be a good idea, starting around post #416.
Sanjay
post #650 of 665
Well, the physics won't generally permit you to remove energy from the mode, unless we go to the absorbtion stuff that I still regard as way too complex for the consumer. So, you don't excite it, or you excite it in a way, using phase or delay, etc, that drives it into a different behavior.
But barring adding absorbtion to the room, or using a very complex system, it's not going anywhere unless you actually eliminate the energy storage in the room. That's what modes are all about, energy storage, when they arise from the physical room arrangement.
HOWEVER: Now we have active devices, things like loudspeakers, that can also arrange to put energy into the room, even at frequencies where the room doesn't store annoying amounts.
And, once again, modes are due to the reflections from the walls.
You can simulate reflections at farther (nearer would be cool (but my thiotimeolene doesn't work yet) ) distances by using delays. You can do this in any number of ways, some natural and some artificial. Again, I point to the method of images, as cranky and complex as it is, for more evidence that this is a valid interpretation.
There is one wart: The difference in the radiation pattern as reflected from the wall vs. emitted from a woofer.
I submit that at bass frequencies, the difference between the wall (planar reflection) and the speaker (simulated reflection from point source) is moot.
So, barring useless semantic dickering, you can add modes. No, they certainly aren't originally present.
Now, if you all wish to argue otherwise, perhaps we should start a new thread on linear algebra?
N.B. "nodes" are not part of this particular discussion, should you read "node" it's evidence that jj's finger did not move quite far enough to the right while typing "mode".
post #651 of 665
This is really interesting and I also think it should be a new thread. Also thinking it would be a very interesting AES workshop and/or paper session. When I get mroe time I would like to try simulating some ideas. To me, I need to see some results. So, I would like to see a spatial plot showing the added modes. That would be very convincing.
post #652 of 665
I don't mind starting a thread, but should it be here or in the audio theory area?
post #653 of 665
Theory.
post #654 of 665
Theory.
Hopefully, the participants will post here-
http://www.avsforum.com/avs-vb/showt...3#post15668293
post #655 of 665
Can't the mods break off part of this thread to start a new thread?
Sanjay
post #656 of 665
I am on to this new thread, let's see if it flies...
post #657 of 665
I have no comment on this.
post #658 of 665
Sanjay
That would be great if they could
post #659 of 665
They can, you just need to ask whoever is modding this particular forum.
post #660 of 665
Originally Posted by jj_0001 View Post
I can't ever guarantee you a demo YOU will find "convincing" since that's a preference issue, and you've already seen one paper, and illegimately dismissed it. I doubt, then, that you will ever be convinced.
I'll quote a person who said to me, at the 'First Conference in Audio in Digital Times", then, when I was showing (at the time) 4 bit/sample perceptual coding: "Mr. Johnston, that is never, ever going to amount to anything."
You remind me of him.
Cheerio, yourself.
Dearest JJ_0001,
Based on your reply, I am convinced Cap'n understands the concepts; presents them in an intelligent light; and believe it would be best for the readers in this blog for you to move on and reconsider posting contradictory, circular, and largely academic concepts.
It's clear, time to move on JJ, let others offer insightful contributions. Perhaps you should consider starting another post about material more familiar to your knowledge base such as a comparison between DTS, Dolby, and Logic7. I would be very interested to read about your findings in this context. Please let us know.
  Back to Forum: Ultra Hi-End HT Gear ($20,000+)
