Originally Posted by CraigW
MonkeyGoD,
When you tested with the 30ft distance, were all the speakers set to 30? I thought the whole distance delay is relative. So if all channels were set to 15ft except one that is set to 17ft the there is no delay between channels that are equal and the 15ft channel signals would delayed by 2ms compared to the 17ft no delay applied (ie. 17 ft max distance would apply to a zero delay)
I could see setting one channel at 30ft and all the others at 1ft and the resulting delay would be 29ms in the 1ft channels. I measured once
Again I would think that the largest distance becomes the reference channel for distance and the reference channel would have a delay of 0ms with all the delays being determined against the reference channel.
I guess to me it just seems backwards that setting all channels at 30ft or 15ft would result in different overall delays with the inputs AV delays set to zero.
MonkeyGoD,
When I measured the delay, I disabled all my speakers except for my mains and i measured my right speaker with a mic pointed straight at it 6 inches away. The funny thing is if I did this with a normal setup, i would get an instantaneous feedback loop squeal, but the audio delay acts sort of a feedback destroyer so i was able to measure it very close up. I measured once with the 805 set at 0ft and again set at 30ft which resulted in the 76ms and 47ms values i measured.
I was only concerned with the total audio delay and not any relative delay between each speaker channel, so I made sure to only measure one speaker. I assume that there is no relative delay between speakers if the spkr distances are set accordingly.
The "bad" thing is I have an old-fashioned "good old" 32" 16:9 CRT, which I am still happy with. So there is no digital image processing going on, hence the picture is as fast as it could be. I have my DVD-player directly hooked up to the TV (via SCART-RGB), bypassing the Onkyo. Noticed the delay then yesterday evening the first time... monitored a while to verify there is an issue, then checked the audio delay setting to find out there were set to 20ms for my DVD-Optical-input and to 40ms for my analogue stereo input from/for my laptop. Where did that come from by the way (preset?) ?
I dunno...
