If you can set the fence on the saw for 24", 23 1/4", 11 3/8", & 10 3/8", and use a circle jig, your good to go
I've got to give Vito props for the motivation to do this one, I like to go BIG, but this was what made sense to me for his setup.
Stats:
24 3/4" H&D by 49" L
~403 Liters as drawn
6" SCH 40 port of variable length up to 37 1/2" as drawn
Tuning ~11.5Hz as drawn
Looks harder than it actually is
You only need 2 sheets of 3/4" MDF to build this box.
First sheet gets cut into 24" wide strips
Second sheet is cut into 23 1/4" strips
The 23 1/4" strips are then run thru the saw again to make 23 1/4" squares
Take 5 of the 23 1/4" squares and cut 20" holes on center
Take 2 of the peices with 20" holes and rip them down to 11 3/8"
Take one of the halves and rip it again at 10 3/8"
I will post later on the port instalation and driver cutout
Later
Dan
