AVS › AVS Forum › Audio › 2 Channel Audio › Help with REL connection to M3
post #1 of 8
I am trying to set connect a REL B2 to an NAD M3 to use with SF auditors.
My question is which input to connect to with "Neutrik Speakon" plug? Balanced or unbalanced? Thank-you.
post #2 of 8
You don't have a choice, do you? The Speakon plugs will ONLY connect to the balanced inputs.
post #3 of 8
Yes, the B3 has an input labeled "high level balanced" and one label "high level unbalance" for the speakon plug as well as a "low level balance" that takes a balanced connector as well as "regular" low level connectors.
Danny B
post #4 of 8
Did you mean to say the M3 or the B2?
Here is the back of the M3. Is yours different?
HERE is a link to the instructions for connecting the REL.
post #5 of 8
My M3 looks exactly like that. I am, however, asking about the connection on the REL B2.
thanks
DannyB
post #6 of 8
I linked you to the instructions for the B2, above.
post #7 of 8
Connect to unbalanced high-level on the REL (label 9 in the manual) the other end will go to your speaker connections on the amp.
post #8 of 8
Thanks. I did that and it seems to work well.
thanks again. DannyRB
