AVS › AVS Forum › Video Components › Home Theater Computers › HTPC - Mac Chat › MacBook and Projector help
post #1 of 3
Hi all. Please help! Here is my setup: 2Ghz Intel Core Duo MacBook, Panasonic AE900 connected by HDMI.
I am trying to send a 1080i signal to the projector, to play HDV home movie files. I'm playing through DVD Player, without interlacing turned on. I had been connected at 720p (the projector's native resolution) but the motion is bad. There is no combing, but it flickers in a way that looks like an interlaced signal that has been deinterlaced rather badly. I hope that by sending a 1080i signal, the projector will render the motion right. I know it can, because the same footage looks smooth (like 60 fields per second) when played from the CAMCORDER to the projector.
Using DisplayConfigX, I am able to create a 1080i resolution that sort of works. BUT: the motion looks really good for about five seconds, then flickers terribly, then recovers. This keeps repeating. All the same, while it is smooth it is definitely 60i smooth.
I need help with the finer timings, I think. The PJ manual says this for a resolution of 1080i:
Horizontal scanning frequency: 33.8
Vertical scanning frequency: 60.0
Dot clock frequency: 74.3
I assume that I need to adjust front porch, etc. to get these numbers exactly. How do I do this? Should this achieve consistently smooth video?
Thanks very much.
Jeremy
post #2 of 3
I'm going to post a follow up to my own question. I think the flicker/judder is a playback issue. This is a MacBook, with no dedicated video ram. I tried playing the HDDVD image folder with VLC, and the problem happened much less frequently, and pausing momentarily occasionally helped.
So it seems that it is hooked up appropriately. With a more powerful Mac, it might be better.
Jeremy
post #3 of 3
I just saw this and I was going to say the same thing. If it wont play on your mac right without a projector hooked up, it won't play right with one either.
I ran into the same issue trying to play an itunes tv show off my wifes dated powerbook into my crt projection tv. It worked great off my powerbook though!
  Back to Forum: HTPC - Mac Chat
