Preface
Now, I know I'm a newbie and all ... but I've been lurking for quite some time. I've searched the forum extensively. I've read the many threads debating the merits of various cables. I feel like I've learned a lot, but now I actually have to make a decision and I humbly seek your opinions to make sure I don't do anything stupid.
My story
I'm building a new house and we're getting close to running wire. My plan is to purchase pre-wiring only from the builder's wiring subcontractor and do equipment installation & integration later on (maybe professional or DIY).
For my AV solution, I'm planning to locate the source devices, matrix switch, and other equipment in a central media closet. I'll distribute component video and audio to the viewing rooms, and control it all via distributed IR.
I plan to put surround sound in the family room and media room. For these two rooms, I've specified 3RG6 (component video), plus 2 Cat5e (one for IR, one spare), plus sufficient speaker wire to the speakers.
For the remaining rooms, I've specified 5 RG6 (component video, plus L/R audio) plus 2 Cat5e (one IR, one spare) to each viewing location.
Furthermore, I've specified the use of RG6 quad shield. The wiring subcontractor was a little iffy on the quad shield. He felt it was overkill (they typically run dual shield), wouldn't be worth the extra cost, but would run it if I desired. It would cost me an extra $100 per run. There are nine runs in total, averaging maybe 50 feet each.
The dual shield cable they typically run is Direct Connect RG63CCS. The quad shield cable they would run is Monster Cable CPRG6Q-500.
Questions
I still prefer the quad shield option. Does that sound reasonable?
If I upgrade to quad shield, they propose to use Monster Cable CPRG6Q-500. Is their proposed cable (monster CPRG6Q-500) a good fit for this application?
(Strangely enough, I can't find detailed specs on this cable. Is it bare copper or copper clad steel? All the hits I get on google just tell me 95% braided copper and 100% bonded foil, which I'm assuming refers to the shielding and not the center conductor.)
Let's say I sold the house to someone who didn't want to duplicate my infrastructure. I'm assuming I could run either CATV or DSS over the same RG6 cables (maybe having to replace the connectors). In other words, would this cable be suitable for either component video or CATV/DSS?
Thanks in advance for any insights.
My story
Questions
