AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "The" Onkyo TX-SR875 Thread
"The" Onkyo TX-SR875 Thread - Page 55
post #1621 of 6031
Originally Posted by illdefined View Post
hmm, check if it happens with FOXHD. if so, i think all the channels you're seeing problems with are the ones that broadcast in 720p..
NBC and TNT are 1080i.
post #1622 of 6031
Originally Posted by sjv View Post
BUMP: NO REPLY
Also, another forum member with a similar question........can anybody help us out here???
I am able to get audio via HDMI with the display off. It does drop out for a moment when you actually turn the TV off, but then it will play without problem.
post #1623 of 6031
Yeah. Another reason I'd buy a Denon over an Onkyo. Tried & true over the years. Something to be said for that.
post #1624 of 6031
Bumping from the last page since I posted this late last night. Will be calling Onkyo today.
Originally Posted by LushMojo View Post
So, here's what I've found. I noticed today while watching Star Wars EP III from On Demand the "motion judder" was present. I tried different settings on the Onkyo to no avail. Tonight I viewed several HD channels and noticed the following:
HBOHD - no issue
StarHD - no issue
ShowtimeHD - no issue
DiscoveryHD - no issue
MOJO HD - no issue
ABCHD - "motion judder" to such an exaggerated extent that the movement of actors seemed to jump occasionally (this occurred on some show called Men in Trees - never watched it before)
NBCHD - "motion judder" while watching ER (not as bad as ABCHD, but still definitely present). Oddly enough, on our local NBC nightly news (the best HD picture I've seen, by the way) there is NO issue. So....same channel but two different sets of content shows issue present and then absent.
TNTHD - "motion judder" while watching some show called Saving Grace. Issue easily identified.
Additionally, while the problem was present on the last three mentioned channels and/or content I adjusted settings on the Onkyo from 1080p to PassThrough to Auto to 1080i to 720p. None of these settings altered the effect. It was still present and unaffected to any degree that I could discern.
Please note that all of these observations are AFTER switching to a brand new Motorola 3412 (and when I say new, I mean I watched them unbox and remove the plastic at the Comcast store here in Boulder). I've had this Sony 46XBR2 since last year and have never noted any issue even remotely like this. I fully believe this is an Onkyo issue. As such if this isn't resolved at some point by Onkyo this unit will either be going back or be for sale.
Anyone with any ideas as to what I might adjust, please enlighten me.
post #1625 of 6031
Could this have something to do with how the signal is output from the box? I realize it is a different box, but perhaps it has to do with deinterlacing or interlacing at the box? What do you have the box set to output, resolution-wise? The reason I am not convinced it is the Onkyo is that you have still the problem after setting the receiver to passthrough. It shouldn't be touching the video signal there. The other thing to consider is the display. I am unfamiliar with it, but perhaps it has to do with the way it is interpreting the signal?
I don't know for sure, just some ideas to throw out there.
post #1626 of 6031
The Comcast box is outputting 1080i. I could try some different settings there. If I change it to 720p or lower doesn't that mean that I wouldn't get the highest resolution available when 1080i is being output?
I tend to think the display isn't at fault (although nothing is impossible). It's in Sony's highest end line and it doesn't display the issue with the other sources I have (DVD or Xbox 360). The culprits in my mind are the Onkyo and/or the Motorola/Comcast box. As for why the PassThrough setting leaves the issue unchanged, I wonder if it's truly leaving the signal untouched. I mean, the signal is still being routed through the Onkyo.
post #1627 of 6031
Lush,
Try hooking the cable box directly to the TV (physically by-passing the receiver) and see if you still see the problem. If so, then the receiver can't be at fault.
post #1628 of 6031
Are you connected from the cable box to the Onkyo with component or HDMI?
post #1629 of 6031
Yes, but, the recent video implementation is pretty new for all manufacturers. So, there really isn't any "tried and true" implementation. Granted, I would probably trust Denon to implement something a bit better than Onkyo, but then again, I was surprised that Denon stayed with the Farudja chip....
post #1630 of 6031
I thought of that shortly after posting earlier. Tried it - all problems resolved with Comcast box connected directly to the Sony LCD. I verified with TNTHD running ER this morning. The motion judder was easily identified with the Onkyo in place. After going direct from the Comcast to Sony the problem went away completely. With the Onkyo back in the loop the issue is there again.
And to gjlowe - everything is HDMI. The only thing I'm using component with is the Xbox 360 (at least until I get the HDMI version next week).
Will be calling Onkyo shortly. I'd say with a good degree of certainty that the Onkyo is at fault. Hopefully, they can advise on setting change or other solution.
Originally Posted by rmb1035 View Post
Lush,
post #1631 of 6031
BUMP: NO REPLY
gjlowe, thanks for your reply. Are you using the DirecTV HR20 DVR or another source (cable box, etc.) for your audio that you're listening to via HDMI with the TV off?
post #1632 of 6031
Has anyone had any issues with the receiver shutting down while doing the speaker level calibration tests? Have 7.1 set up, going through the speaker level calibration test, all the speakers work fine, except when it gets to either front right or surround right, the unit shuts down. Sound comes out of these two speakers fine while watchng tv or dvds, but while trying to play an audio cd in the dvd player the unit shut downs right away also. I have not yet tried hooking up an Ipod or something else yet, but I will later tonight and I will also try disconnecting those two speakers and seeing if the unit still shuts down. It just seems odd that they work for tv/dvd playing but not audio or level calibration tests. Has anyone had any similar issues?
post #1633 of 6031
Just called Onkyo. Spoke to a guy named Eric. He's going to set this up in their lab and give me a call back with results next week. In the meantime, he suggested doing a reset.
Those of you that mentioned seeing motion judder issues - would you mind posting about any testing you've done? Thanks.
post #1634 of 6031
Using the Motorola 3416 HDMI to 875, HDMI to Samsung 4665F I am also able to turn the Display off but there is no audio dropout or delay associated.
If anyone is having problems with this LCD they should read the Samsung thread for this TV. There have been problems with the main pcb board. I think the minimum without issues were revision pcb 1008 and firmware 1028. These were all HDMI handshake issues with dropouts.
post #1635 of 6031
I wrote before that I have been having this issue as well. I have a 52in Sammy 65F and a Dish Network VI622 HD DVR. Everything is connected with HDMI cables from Blue Jeans Cable. I never saw this problem before I bought the 875 and started noticing it after the 875 was in the mix. The channels I've noticed it on were Kung Fu HD and TNTHD among several others - these two most noticeable. I also set the receiver to pass through and still noticed the motion judder. I then hooked the sat box directly up to the TV (even though like I said earlier - I never noticed it w/o the 875) and the problem was corrected. I hope Eric can get something figured out. Thanks for doing that legwork Lushmojo. Out of curiosity, does anyone know if anyone with the 905 has been experiencing this issue? Hey Lush, did the reset correct the problem for you?
Guzz
post #1636 of 6031
Haven't done the reset yet. Will probably do that this weekend. If you get time, call Eric at 800.229.1687. I'm sure more data will help him with his setup. This is bound to end up affecting a number of people.
Thanks for the reply. Will post my reset results when available.
Guzz
post #1637 of 6031
I have a similar issue too. Anybody have an answer for this one?
post #1638 of 6031
I had an 875 preorderd from J&R and finally got tired of waiting and last week ordered an 3808 from ABT. However, I am running into problems already. I have an original Xbox 360 (no HDMI output) so I am attempting to output 1080p via component video to the 3808 and then output it to my projector via HDMI. It looks like this will not work at all, and reading the instructions seems to verify this. I've tried to downcovert the signal to 1080i or 720p and doesnt seem to work either.
Does anyone know if the Onkyo is any better at this? Can the 875 accept 1080p via component and then output 1080p via HDMI? Or is that just not technologically possible? Any advice would be appreciated! I still have time to return my 3808
post #1639 of 6031
I also preordered and just got mine yesterday. After talking to a couple of different reps I figured out that there were 10 preorders, 16 delivered in first delivery and another 110 on there way to J&R. I ended up arguing with the rep and got one of the last ones from the original batch. If anyone else is on the list there, call up and argue until they send one or get a price reduction.
post #1640 of 6031
Well that's so nice to know. Thanks for posting that in an Onkyo thread because those of us that care aren't smart enough to look at the Denon threads to follow all the problems people are having with their new receivers.
And to think, if Denon hadn't put an inferior video processing chip in a receiver they are charging $500 more for, the choice between the Onkyo and the Denon might be obvious.
post #1641 of 6031
If the Denon had Reon... there would be no doubt in my mind, I'd save a few more pennies, and go with that, but the fact that the 3808CI and the SR875 are so closely matched, with different pros and cons makes it an extremely tough decision. At this point, aside from aesthetics and assigning inputs the Onkyo still seems like the best deal, especially as authorized dealers are so eager to sell for less than MSRP, not so with the Denon I've found.
post #1642 of 6031
I have the 875 being fed by Directv HD20. I am outputing 1080p into my KDL52XBR2. I have no issues with judder. In fact, I am very happy with the processing the Reon chip does for both SD and HD signals. Although, I would prefer to have the control of the Reon ship that 905 owners have.
post #1643 of 6031
Hey, that's why I'm still shoppin', brother. Haven't bought the Denon or Onykyo. Owned units from both over the years, and the denon was better. Granted this was about 8-9 years ago, and the tech has sure changed. But the Onyko crapped out and the Denon is rolling along nicely at my parents.
You're also making the assumption that the implementation of the DCDi video chip in the Denon is inferior vs. implementation of the Silicon Optrix one in the Onkyo. Except I haven't seen any side by side objective (note: NOT subjective)reviews yet. Have you? Furthermore, the issue that arose a few posts above, that issue I commented on, was the performance of the Onyko with a particular Comcast STB. I happen to have Comcast and amazingly, the same model STB. So, when I hear that someone has an issue with that combo, it certainly raises an alarm. It will be interesting to see how it plays out.
Caveat emptor...
post #1644 of 6031
Edit: I don't think the XBox / 360 1080p input over component works even it's when switched to HDMI (1080i works just fine). Basically, I got a blank blue screen on my 60A2000 after switching to 1080p output. In any case, you can always output at 1080i if needed and let the Reon's excellent deinterlacing handle it...
post #1645 of 6031
Perhaps there's a difference in how the DirecTV box and the Comcast box talk with the Onkyo. Thanks for the input.
post #1646 of 6031
If anyone is looking to purchase the 875 they are some out there already as of today with decent pricing. Just giving you guys a heads up hopefully the trend is turning.
post #1647 of 6031
Can you say where?
post #1648 of 6031
With regard to the comment about buying Denon at MSRP....Best Buy sends me 12% off coupons all the time, and the Magnolia people said that would be pleased to extend that offer to Denon units (they did have 3808 in stock). I am waiting, however, for a Reon bearing unit from Onkyo.
post #1649 of 6031
Well I just confirmed that my setup does play audio from the PVR when the TV is off. When I turn off the TV the audio drops out for a few seconds, and it lasts long enough that in the past I figured it just didn't work and would turn the TV back on.
post #1650 of 6031
That's great news I like to tune in D* and listen to the music (XM) channel (smooth jazz) thru my receiver and speakers with the TV turned off.......we do that a lot during the day.
