Originally Posted by Jim Cate
I'm interested in the SR875 (and possibly the 905 or 805), but my front speakers (Magnepan 3.6r's) need to be driven by an amplifier with lots of power and current. I would like to use one of the Onkyo AVR's (because of their many features), but I think I should continue to drive my Maggie 3.6rs with my present external amp (a large Rotel unit with lots of power at 4 ohms). My other speakers (center, surrounds) are smaller and less power-hungry, and I would propose to use the amps in the AVR to drive them, but I would like to use the preamp outputs on the AVR to drive my Rotel amp for the front channels.
Would this be a good arrangement or not? I ask because the owners manual for my present (legacy Onkyo) AVR specifically states that the audio amplifier outputs should be turned OFF if using the preamp outputs. Is this necessary or essential for good audio, and is it also the instruction given in the OMs for the new Onkyo AVRs? If it is, I couldn't very well use the front preamp outputs but not all of the preamp outputs. (Of course, another alternative would be to use all the aVR preamp outputs and connect them to my other power amps.)
Thanks for any inputs or suggestions.
Jim Cate
Jim Cate
Why not look at the Integra 9.8 pre amp? Made by Onkyo -- the same or similar to the 875 or 905 without the poweramp.
Another thought, the 875 is THX rated and has enough power to turn any speaker I've ever owned to confetti.
You'll definitely need some fans (search previous posts). But with 1" clearance I don't know how they'd fit.
Ok seriously that is annoying but there may not be an good way around the issue. HDMI seems to be really slow when changing the resolution between stations and even audio changes on the same channel can cause slow audio switching. Gotta love the bleeding edge of technology.
But it's available on this string or
