Originally Posted by Doug Blackburn
The issue comes up because the lower cost stand-alone processors' prices tend to start at $1500 or so and go up from there. An AVR model without the amplifiers but similar sound quality if you bypass the amplifiers may sell for $1000 or even less. The surround processor may carry some extra features like XLR inputs and/or outputs that the comparable AVR doesn't have - but the circuit boards inside may be the same circuit boards used in a less expensive AVR.
As you move into higher price ranges and non-Asian manufacturers, you tend to see processors that may not have AVR "brothers" - but if the company does sell an AVR, there's a good chance there's a lot in common between the AVR and processor. We assume a $2000 processor is going to be "better" than a $2000 AVR, but it may not necessarily be true if you bypass the $2000 AVR's amps. Now... if you are going to spend $2000 on a processor, you probably would go for the stand-alone processor since there's no reason to confuse things with idling amplifiers in a $2000 AVR. But if you can get a $1000 AVR that sounds as good as a $2000 processor... bypassing the internal amplifiers might sound like a great way to save $1000 since you are going to have the external amps for the $2000 processor anyway.
When I review an AVR, it is always helpful to know how the front-end performs and how the "back end" or amplifier section performs as separate entities even though few owners may ever use the AVR that way. But some enthusiasts on a budget might consider something like an AVR selling for, say $800 or even less if the front-end sounds great because their stand-alone processor options may not start until well over $800. They won't care about the amplifier sound as long as the front-end processing works well.
Something very significant happened with the sound quality of AVRs in general about 3 years ago - I still don't know what it is... but it is NOT digital amplifiers as the AVRs I find to have good-sounding amplifier sections don't have digital amplifiers. AVRs still can't control a speaker like a decent stand-alone amp... they just don't have the power supply capability to provide the drive capabilities, especially in the bass octaves, that you get from a good standalone amp. Of course, the whole AVR may cost less than a good stereo stand-alone amp... you do (often) get what you pay for in external amps. I have stereo amps here that have a transformer or transformers that weigh more than entire AVRs... and that's a key to getting superior current-drive and control capabilities. The sound quality improvement in AVR amps has been observed in AVRs with both integrated circuit amps and discrete transistors. I remain a non-fan of digital amplifiers, though some standalone high-ish-end digital amps are starting to sound pretty good.
Another AVR feature that had been appearing in more and more AVRs in recent years is the ability to assign amplifier channel in several different ways including bi-amplifying the front main speakers - this has made a HUGE difference in driving my reference speakers (Vandersteen 3A Signature nominal 6-ohm rating with 2 or 3 dips to 4 ohms or so). A single 125 watt AVR amp driving these speakers typically sounds very uninspiring but when these are bi-amped with good AVR amps, they sound FAR better... good enough that one could live with the AVR's amps whereas 4 or more years ago, an AVR in a similar place in the product line (no fair comparing an earlier top of the line model to a current middle-of-the-line model) would not produce sound that's very listenable.
If you are discussing top of the line AVRs ONLY... I don't see the big changes I've encountered in mid-priced and lower-priced models. Denon's top of the line hasn't changed much over the years, for example.
Well that could likely be the case...but I consider the 875 on the higher end of AVR's...and I was only comparing it to older units that were on the higher end of AVR's. The AVR's I mentioned earlier were all THX ultra rated...excluding the Yamaha RX-V1 and I am certain it would have passed..for some reason Yamaha didn't want to pay the licensing fee
Getting back to the receiver as a pre-amp. I don't recall anytime where there was a "mid-line" line preamp. They were always on the upper and high end of the product range
To make it easy..you can use the Onkyo products as examples...my Prsc885 preamp is basically a 905 without the amplifier section....as is the PRSC886 is just like the 906 minus the amps...both pre-amp units were less expensive than their receiver brethren . Like the receivers they could be bought as refurbs from Shop onkyo or accessories4less. For the record the 3 onkyo pieces I have purchased have all been refurbs from one of those establishments
I make some assumption here that the 905 has some sound advantages over the 875( ditto with 906 over 876) that are non-amp related.
I also know that a good mutichannel amp is going to cost more than the difference in the pre-amp and receiver....but any good amp is likely to outperform the internal amp of one of those receivers...especially in a low impedance situation at high volume levels
That being said...and I guess I need to address this in the 905/906 forum if it applies
Why would someone buy a high end receiver and use a separate amplifier?
That is not the least expensive alternative for the same sound
The other preamps..Lexicon...Meridian..Classe..etc...are not part of the equation as I consider them to be a of better sound quality and much higher pricing than anything in the Onkyo line..preamp or otherwise
Warren
Last night we watched the original X-men on blu, and a scene where Storm was fighting Sabretooth, "lightening" crackles shut dowm the reciever.
